Page 3 of 18 FirstFirst 1234513 ... LastLast
Results 21 to 30 of 171
Thread: Installing the V8 Software
  1. #21
    Take a look at the document available as part of the V8 software called:
    Start->All Programs->EFILive->V8->Documents->Upgrading Firmware
    You most likely will need to make sure your FlashScan is at firmware V2.04.72, then do a boot block upgrade on the device.
  2. #22
    Oct 2004
    LOL. You were too quick Paul.
    Check this knowledgebase article which describes the process for updating FlashScan bootblock/firmware. As Paul says the most important thing to ensure is that you first upgrade to 2.04.72 before attempting to update to 2.05 and later.
    Andrew
    EFILive Crew
  3. #23
    Jun 2011
    Thanks for the info. Much appreciated!
  4. #24
    Apr 2011
    hello all,
    i'm a new entry of the forum, i say everybody hello!
    i'm getting a trouble with the efi scan and tine, when i oush on "tune" i'm getting this error
    "unknown picture file extension (.#252#234#224)"
    i need new vesion to work on E78 controllers, with V7.5 i have never had troublen and i dont have either with V8 in a win 7 laptop
    in the one i use to tune the car i have win XP and i'm facing this issue
    thank to all
  5. #25
    Quote Originally Posted by marcoverrocchio View Post
    Currently, the EFILive software is handling non-US settings in Windows incorrectly. Until we get that fixed, please try this:
    On a Windows 7 system:
    • Go into ‘Control Panel’.
    • Choose ‘Region and Language’.
    • On the ‘Formats’ tab choose ‘English (United States)’ format.
    • On the ‘Location’ tab select ‘United States’.
    • On the ‘Administrative’ tab click the ‘Change system locale’ button and select ‘English (United States)’.
  6. #26
    Jan 2011
    FYI – I just updated my V8.2.1 to Build 170. When I downloaded Build 170 and installed it, and then opened S&T, it indicated that it was indeed Build 170. However, when I went to V8>Tools>Check for Updates, and had it download and install the updates, re-opening S&T indicated that it was now Build 160. Maybe a minor issue, maybe not.
  7. #27
    Quote Originally Posted by cmkelly01 View Post
    The update has reverted your install back to build 160. I recommend re-installing from the files you downloaded to get back to build 170.
  8. #28
    Jan 2011
    So, on the EfiLive Download Software web page where it says "After installing, please check for new updates using:
    Start->All Programs->EFILive->V8->Tools->Check for New Updates., I should ignore that? If so, is that just temporary for this particular build? Seems like I won't be getting some necessary updates when I do skip it. Thanks.
  9. #29
    May 2009
    Maybe it's just me...but is anyone else having a problem doing a Crank Relearn since the update??
    Trailblazer "RS" 5.3L 6L80 4x4 & '07 TBSS LS2 6L90 AWD
  10. #30
    Please do not use Check for Updates until further notice.
    You will see new versions posted in this thread (which you can install by directing executing the .exe):
    Software-Updates-and-Installation-Help
  1. Installing the V7.5 Software
    Last Post: February 9th, 2021, 11:28 AM
  2. Installing new ECM - What to expect??
    By juscruzn in forum Duramax LLY
    Last Post: February 1st, 2010, 09:46 AM
  3. installing drivers for new 7.5.5 v2
    By Adam Calley in forum Gen III V8 Specific
    Last Post: April 15th, 2009, 08:12 AM
  4. Installing new firmware
    By black346 in forum FlashScan V2
    Last Post: March 29th, 2007, 09:02 AM
  5. Installing Custom OS
    By oztracktuning in forum Custom Operating Systems
    Last Post: April 27th, 2006, 09:58 PM
