Page 17 of 18 FirstFirst ... 715161718 LastLast
Results 161 to 170 of 171
Thread: Installing the V8 Software
  1. #161
    Sep 2007
    I was trying to update from firmware version 2.04.72 and boot block 2.04.10. I started by updating to firmware using instructions from EFI live dated March 12 2010. But I could not find all the previous firmware’s and boot blocks to follow the sequence of updates listed in the instructions. So I jumped to firmware v 2.07.140 and when I went to do the boot block the FSv2 was unresponsive. So I figured I needed to do what Blacky said in post #155.
  2. #162
    Nov 2005
    Quote Originally Posted by ThunderDan74 View Post
    I'm not actually sure you could program V2.07.140 firmware into the V2 with a 2.04.10 bootblock - I'd suggest that step would fail. It's Saturday here so I can't elevate your support request until Monday. My suggestion in the mean time would be follow the recovery steps word for word - power up the V2 in boot mode, reprogram the V2.05.15(0326) firmware and then move forward from there.
    All of the recovery & update from 2.04/2.05 firmware and boo tblocks are located in the same location as the ReadMe.txt file in the C:\Program Files (x86)\EFILive\V8\Firmware\EFILiveRecovery directory.
    Cindy
  3. #163
    Sep 2007
    Ill give that a shot. In the meantime here is what made me think I had updated. But currently it's all N/A as I can't get it to fully Boot up.
Name:	EFI Live Capture (2).PNG
  4. #164
    Sep 2007
    When I follow those instructions, the all I see is the EFI Live splash page and the Blue LED when I get to step 3, I cant get to the main menu on the Flash Scan. Since step 3 is an "IF" statement, I figure I can press on to step 4 but when I click Program all I get is Error: $0001: USB device not connected
  5. #165
    Sep 2007
    Great news, I fingered it out! Since I had booie-ware recent enough, 2.04.008 I think, I was able to go ahead and update to the 3rd FW packaged with the recovery files.
    Damn, I've been a member here for a long time now. I guess I just won't earn my participation trophy here, will I?
    Last edited by ThunderDan74; August 8th, 2020 at 10:58 PM. Reason: Deleted tapa talk S9 free ad. They didn't pay me for that
  6. #166
    Cool
    Ahh, here ya go... found this down the back of the couch...
  7. #167
    Sep 2007
    Nice. I'd like to thank the flying spaghetti monster for this award. His noodley appendage hath touched me.
    Sent from my SM-G960U using Tapatalk
  8. #168
    Apr 2022
    So I am completely new to the tuning world of Diesel. I just bought the EFI Live Autocal V3. My truck is deleted which is what lead me to this tuner. I downloaded the software and everything else that I am suppose to do per instructions...or so I thought. I plugged the tuner in and it only shows Stock & Towing options for flash. I can't select anything else. There is the tune section that shows Stock, Economy, Tow, Performace and something else...but I get an error code every time I try to select any of these options. My tuner seems very limited in what I can and can't do which leads me to believe that I am missing something. Is there someone that can help me out?
    Thanks!
  9. #169
    Hi Strozzi,
    You are possibly missing purpose of an AutoCal device. You cannot create/edit tunes for you truck using an AutoCal device. For that you would need a FlashScan device.
    An AutoCal device is simply a delivery mechanism to allow a professional tuner to deliver tunes to his/her customers. you would need to contact the tuner that supplied the AutoCal and the tunes on the AutoCal for one or more tunes that are suitable for your truck.
    You can read more about AutoCal here:
    https://content.efilive.com/document...er%20Guide.pdf
  10. #170
    Apr 2022
    Blacky,
    I'm not trying to create or edit any tunes. With the V3 when I go into the Tune and select my features, it gives me options of stock, economy, tow, performance etc. Before delete I ran a smarty JR67 which also had the preloaded features, so I could select one and it would tune my truck. My mechanic ordered me this so that I could switch what tune I want to function with depending on what I'm doing.
    Strozzi-
  1. Installing the V7.5 Software
    Last Post: February 9th, 2021, 11:28 AM
  2. Installing new ECM - What to expect??
    By juscruzn in forum Duramax LLY
    Last Post: February 1st, 2010, 09:46 AM
  3. installing drivers for new 7.5.5 v2
    By Adam Calley in forum Gen III V8 Specific
    Last Post: April 15th, 2009, 08:12 AM
  4. Installing new firmware
    By black346 in forum FlashScan V2
    Last Post: March 29th, 2007, 09:02 AM
  5. Installing Custom OS
    By oztracktuning in forum Custom Operating Systems
    Last Post: April 27th, 2006, 09:58 PM
