Page 13 of 18 FirstFirst ... 31112131415 ... LastLast
Results 121 to 130 of 171
Thread: Installing the V8 Software
  1. #121
    Dec 2006
    That is correct. Registration won't be necessary until the V8 Tune Tool editor is released. And even then it may end up not being required.
    Thank you my old friend!
    8.7 @ 84 (1/8 mile) bolt-ons
  2. #122
    Oct 2010
    I'm back to the EFIlive world and updated my flash scan too. I downloaded the V8 and uplated the build 303. GOt the bootblock and firmware to update but it has a bunch of trans TCM that need updating and when I try to update I get this. any tips? i'm excited to start tuning my LML
Name:	efi screenshot.png
  3. #123
    Support for the E86 controller has since been split into E86A and E86B and all files have been renamed accordingly. You should reformat the [Config] file system and then re-setup the controllers that you want supported on your FlashScan using the [F5: BBX] option in the V8 Scan and Tune software.
  4. #124
    Oct 2010
    Wow I feel dumb since I have been out of efilive for awhile. What did you just say lol, that was for me right blacky? If it was how do I know what controller to use the A or B?
  5. #125
    The Durumax family on EFILive:
    The E54 controller is for LB7
    The E60 controller is for LLY
    The E35A controller is for LBZ
    The E35B controller is for LMM
    The E86A controller is for LML 2011-2014 (this used to be called just E86)
    The E86B controller is for LML 2015+
    So if you previously used E86, then you will now need to use E86A instead.
  6. #126
    May 2007
    i bought a new laptop and its a Lenovo with windows 10. I downloaded v8 and v7.5 straight off efilive.com but now need to connect my v2 and get it operational as my old windows xp keeps randomly shutting down.
    any tips to make this painless, doing updates and changing pc is the part that scares me. tuning on my car is the easy part to me. thanks, Chad
    2000 NBM trans am.
    427 Dart ship block,Lme ported Ls7 heads 12.5 compression
    246/262 .730/.712 112+4 low lash solid roller
    Rmvb 4l80 with transbrake, 8" FTI converter
    12 bolt Moser rear end with 4.10 gears
  7. #127
    Install V8, install V7, copy your tunes/logs to new PC/laptop, copy contents of folder User Configuration to the same folder on new PC/laptop, plug in FSV2, start V8 S&T.
  8. #128
    New Member ajmac's Avatar
    Aug 2010
    I've been out of the EFI Live circle for about 10 years and haven't plugged in the V2 since 2008 . Downloaded V7.5 and V8 to my desktop, plugged in my V2 into the usb on my desktop and all I have is alternating flashing lights on position 2 and 4, the screen is dim but I can barely read "boot block upgrade." This has been going on forever....any clues? I have searched the threads but not much info on my issue.
    16 Silverado LTZ Z71 6.2 4X4
  9. #129
    Quote Originally Posted by ajmac View Post
    It appears like you've just updated the FlashScan V2 boot block from V2.04.xx to V2.05.xx using the built in boot block upgrade process.
    Run the V8 software and select the menu option: Help->Documents->FlashScan->Upgrading FlashScan.pdf
    That document will step you through the process. You appear to be already up to the stage mentioned on the bottom of the fifth page (sorry there's no page numbers, you'll have to count), where it says:
    The upgrade process will only take about 5 seconds to complete, then the screen backlight will be turned off. The final message: BOOTBLOCK UPGRADE IN PROGRESS DO NOT INTERRUPT will still be visible. Once the backlight has been turned off that message no longer applies.
    So really all you need to do now is to re-program the correct firmware for the current boot block version in your FlashScan. That document will explain how to do that and what versions of each sub-system you should use.
    Note: If you select the "upgrade boot block option" when your FlashScan had a version of firmware that was not V2.04.72 (i.e. V2.04.71 or V2.04.70 etc) then you may need to use the recovery process explained in the file:
    \Program Files (x86)\EFILive\V8\Firmware\Recovery\ReadMe.txt
  10. #130
    Aug 2010
    Thank you Paul,
    I will give it a go and post my results.
  1. Installing the V7.5 Software
    Last Post: February 9th, 2021, 10:28 AM
  2. Installing new ECM - What to expect??
    By juscruzn in forum Duramax LLY
    Last Post: February 1st, 2010, 08:46 AM
  3. installing drivers for new 7.5.5 v2
    By Adam Calley in forum Gen III V8 Specific
    Last Post: April 15th, 2009, 07:12 AM
  4. Installing new firmware
    By black346 in forum FlashScan V2
    Last Post: March 29th, 2007, 08:02 AM
  5. Installing Custom OS
    By oztracktuning in forum Custom Operating Systems
    Last Post: April 27th, 2006, 08:58 PM
