Results 1 to 10 of 20
Thread: Need Help w/LC1 Serial Logging
    Jul 2007
    Default Need Help w/LC1 Serial Logging
    What can do so far:
    log analog voltage BBL
    log analog voltage and AFR via laptop
    VIEW serial AFR via FlashScan Only.
    What I have not been able to do:
    1) How do I BBL a SERIAL LC1 w/BBL only so I can view later in scanner software.
    2) How do I log a SERIAL LC1 w/laptop
    FlashScan displays a 25:1 AFR when using this method. And yes, I have it setup for Innovate.
    3) How do I log SERIAL LC1 when in pass thru mode?
    I know I'm missing something simple.
    07 Silverado DMax Classic
    02 Z06 LS3 416, 805rwhp, TFS245, Wiseco, Callies Crank/Rods, Iskendarian Lifters, Crower Rockers, FAST102/90, ATI Damper, 1-7/8 Kook's LT, QkTime Shield,Tolle-Fab 8pt
    Old Engine: 1/4mile = 9.6/146 New Engine:?
    EFI Live Tune/Scan v7.5.27, EFI Live Scan and Tune v8.2.23, build 276, BootBlock 2.07.06, FirmWare 2.07.52, 512K RoadRunner (12.14.R), Innovate Serial LC2x2
    COS5/12212156 For 2002 Z06 Manual Vette
    Lifetime Member Garry's Avatar
    Jun 2006
    Did you select the correct WBO2 controller in the V2 setup screen? If so, serial data should be automatically added to your BBL file ... just remember to select the serial PID AFTER loading the logfile ... data should then be available ...
    Garry Glendown * '17 Fifty 2SS MT * 99 Firehawk Convertible (for sale)
    Jul 2007
    Quote Originally Posted by Garry View Post
    and WHICH pid would that be? Thanks. I've got ext.wo2afr1 now. The AF is 25:1 And just so I'm clear, you DO NOT need the analog lines hooked up when logging serial to get the data do you
    Using the FlashScan, I set it up for the Innovate I have.
    Jun 2006
    Correct, analog isn't required once you're running the digital link to the Innovate ... did you check some of your bbl-files and see if there's any data in there once you load and then select the PID?
    Jul 2007
    ok, figured out that its logging the data now. Only probleml the data is
    always equal to 25:1 A/F. The FlashScan device shows the correct A/F and the analog lines do as well.
    are there settings in the FlashScan device I must set to use this? I already turned on Innovate as the wideband type.
    Whatever is happening I think is at the level of the BBL and FlashScan.
    I am going to trash the current options.ini and try stock download.
    Ok, made no difference. still 25:1 A/F
    Senior Member Hyper99's Avatar
    Oct 2005
    Same problem - but not the same value.
    Mine was working fine, but now reports AFR of 5.25 +/-
    The Analog output is correct and if I connect it back up to Logworks through the serial connection, the values that Logworks comes up with are correct.
    Latest firmware and config files - formatted the device, rebooted, re-flashed the firmware, re-copied the config files, same results??
    99 Silverado 2500 Extracab Longbed
    33" BFG's - American Racing Rims
    Custom Dual Upper console gauge mount w/Autometer Sport Comp - Pyro, Oil Temp
    Autometer Sport Comp Boost/Vac in Custom Hypersonic Gauge Mount in dash
    LS-1 6.0L w/AFR 205cc Street Heads
    Vortech V2 blower
    42# Injectors
    Comp Cam - Custom Street Grind
    TTS Catback Exhaust
    Innovate LC-1 Wideband O2
    Tune and Trans mods via EFILive V1-V2
    Jul 2007
    Quote Originally Posted by Hyper99 View Post
    Mine never changes. Value is always 25:1 no matter what the AF really is.
    Hmmm....
    Sounds like either your LC-1 is not working or it needs a heater calibration and/or a free air calibration.
    You say LogWorks shows the correct AFR...?
    Which version of bootblock/firmware are you using...?
    Oct 2005
    Yes - Logworks shows 15.8 at idle
    V2 shows around 5.23
    Downloaded all the latest stuff. Clean installs on both 7.5 and 8.1
    FSProgV2_05_17 - Firmware
    FSBootV2_05_08(0425) - Bootblock
    Vortech V2 blower
    42# Injectors
    TTS Catback Exhaust
  1. Tutorial: FlashScan V2 Serial Wideband Logging
    By TAQuickness in forum Tutorials
    Last Post: July 22nd, 2015, 10:47 AM
  2. BEN is only for analog, right? How do I log BEN with serial logging?
    By Supercharged111 in forum General (Petrol, Gas, Ethanol)
    Last Post: July 12th, 2009, 06:08 PM
  3. Using inverter for laptop + FS V2 with serial logging
    By Dopey in forum FlashScan V2 BB Logging
    Last Post: September 10th, 2008, 08:37 AM
  4. Problems with AEM Uego serial logging....
    By BlackGMC in forum FlashScan V2 BB Logging
    Last Post: July 19th, 2008, 04:53 PM
  5. LC1 Serial Logging
    By oztracktuning in forum General
    Last Post: November 8th, 2005, 06:45 AM
