Page 1 of 3 123 LastLast
Results 1 to 10 of 27
Thread: MAP sensor calibration
    Default MAP sensor calibration
    Has anyone else an opinion on what the problem is here?
    At or near seal level, MAP and Baro should be equal. I have noticed idle (no boost) MAP is around 12.0 psi, instead of the expected 14.x psi. Location error, or calibration issue?
    This has been observed on multiple LMM's.
    Custom Tuning Services
    Jul 2008
    Thats at Key-On, engine not running yet. At that point (before ignition) BARO and MAP would be equal at sea-level (perfect vacuum). At Idle, you have vacuum, so that correlation would not exist.
    Is that what you are asking?
    I don't see how it is even remotely possible to have 2 psi of vacuum at idle at that location, but I am willing to listen.
    Thanks.
    Jul 2008
    Thanks.
    Maybe I am not understanding your question/premise. BARO and MAP will be equal at Key-on at sea-level. Are you saying there is an issue with the Idle MAP?
    My only point is that MAP and BARO are not equal at Idle..only at Key-on. If the Idle MAP is off..maybe I missed the premise of the question.
    Edit: I am working off the premise of a 1 BAR system. If boosted, there may be some assumption I am missing. The only other condition to consider would be MAP Voltage. 0.0 Voltage does not always equate to 0 kPA ( I hit 0.0 at 14 kPa), but I am not sure what your MAP sensor Voltage maxes out at..
    ..So hopefully we are taking about the same issue here..if not perhaps someone can clarify..
    Last edited by WeathermanShawn; June 22nd, 2010 at 12:47 AM. Reason: Clarification...
    The OP's asking about diesel system... no throttle blade so no vacuum due to throttle.
    Jul 2008
    Yea, I have to give up ever answering another question that relates to diesel. OP, forgive my ignorance..I need to read up on diesel's for about a year..
    Actually, in the LMM there is an intake valve, used mainly for reducing oxygen/increasing EGT during dpf regeneration. But it does not appear to be the issue, as one of the trucks I logged has it removed.
    Is the MAP sensor only good to 37 psia?
    That 37 psi cap on the log is a PIA. What happened to 3 Bar?
    Thanks for the feedback guys.
    Jan 2008
    LMM's only read to 37? I'm pretty sure i've seen my LBZ in the 40's.
    Feb 2007
    Try using the Boost2_DMA PID. I have done a bunch of logging on my dad's LMM and his Baro matches perfectly with that PID, and it goes up to at least the mid 40s, probably higher.
  1. E38 fuel level sensor calibration
    By harascho in forum E37, E38 & E67 PFI ECM's
    Last Post: November 29th, 2009, 02:39 PM
  2. AutoVE MAF sensor calibration
    By Ritch in forum Gen III V8 Specific
    Last Post: June 21st, 2007, 09:33 AM
  3. New pcv - knock sensor calibration?
    By voda1 in forum Gen III V8 Specific
    Last Post: June 1st, 2007, 07:42 AM
  4. Which MAP Sensor?
    By mistermike in forum General (Petrol, Gas, Ethanol)
    Last Post: May 13th, 2005, 08:01 AM
