Results 1 to 8 of 8
Thread: What could cause timing to be pulled with no KR detected?
    Senior Member ArKay99's Avatar
    Apr 2004
    Default What could cause timing to be pulled with no KR detected?
    I was at the dyno yesterday and was tuning in my PE. I was geting some knock detection ~4.5 degrees so I added some Torco. The knock detection went to 0 and stayed there. However, I am showing between 25.5 and 26 degrees of timing in PE until rev limit. I have my high octane table at 28 degrees in the PE area and the low octane table is at 24 degrees. Intake temps were in the 32C range and that is zero in that area. Burst Knock Delta is set to 0. I was in cell 22 when monitoring this.
    Any ideas?
    Go:LPE 403, VaraRam, Haltech, PowerMax 100mm MAF, Tony Mamo ported FAST90/NW90, 160* stat, Kooks, TI's, DRM cutouts, Ripper, 4:10's, Tex OZ700, QA1's, Tony Mamo ported AFR 205's, 242/242 .610/.610 114LSA+2, Yella Terras, 42lb/hr Green tops, ASP UD pulley, 2 AMW catch cans
    Show: Euro tails & mrkrs, Z06 chromes/Pilots, 300Wx2 Bolt w/12" Sub,
    red calipers & black rear letters, Zaino.
    530 RWHP, 479 RWTQ
    Oct 2006
    Hi there, where you monitoring you Adaptive octane scalar pid ? if you have had knock it will more the likely be below 100% you can copy your high map into your low map and recheck to see if that was the cause, our use COS3 to set the scalar to 100%.
    Apr 2004
    I was thinking something like that could be happening, but I wasn't sure what pid if any would show me. I am using a 2002 Z06 OS. I know there is an adaptive spark pid, but I wasn't sure how it monitored the tables. I thought that it just told you if you were in the high or low octane table, but if holds some value as an upper limit that would explain that.
    If that is the case the next question would be, how would I go about 'zero-ing' this value since I was no longer monitoring knock due the use of additional octane?
    530 RWHP, 479 RWTQ
    Oct 2006
    The adaptive spark pid indicates where the timing is being calculated between the high and low spark maps (interpolation) 100% means it using the high map, 0% its using the low map, 50% is half way between the two etc etc.
    If you no longer have knock and the adaptive spark is below 100% just reflash the tune and it will reset to 100%
    Or you can install a custom operating system and then command 100%, the down side to this is you then have no adaptive spark and only knock retard
    Apr 2004
    Hmm, I was reflashing as I was tuning in the PE. Well, We'll never know because I wasn't logging that pid anyway.
    However I will be going back in the early fall to do some more tweaks and I can monitor it then.
    530 RWHP, 479 RWTQ
    Lifetime Member Kevin Doe's Avatar
    Aug 2007
    If you set burst knock delta to zero, wouldn't that cause you to always have burst knock active? It says if the delta value is exceeded then burst knock will be active. If you set it at zero, any throttle movement will cause it to be in burst knock. I think you need to increase this value, not set it to zero.
    Apr 2004
    Quote Originally Posted by Kevin Doe View Post
    Again, It seems misread the explaination, but the values in that table are from the OEM LS6 calibration. I didn't put them there. According to the pid description this must have been what was causing the lower than commanded timing.
    I'm going to have to look at this pid while logging on the dyno to see what different values do.
    530 RWHP, 479 RWTQ
    Feb 2004
    I have a similar question. I already set my high and low timing tables the same, and set my wot region to a flat value (14) and set my base spark in gear also (20). In my logs with the EST pids selected it shows 14.2* base spark, 9.x* Brake Torque Retard, 4* EQ ratio spark (wtf is this btw?), and 18.2* for run spark. The timing for cylinder 1 shows 17.5* though, and none of this matches the tables in the tune. Any ideas how to find my timing?
    Side question: any ideas for reducing the lean spike on tip-in?
    01 C5 'vert A4
    EFILive, PLX, & TNT are all we got at the moment.
  1. pcm noy detected on scan only wtf?
    By z28ls1818 in forum FlashScan V1
    Last Post: December 15th, 2009, 04:32 AM
  2. error interface not detected
    By drdarthinvader in forum FlashScan V2
    Last Post: December 7th, 2008, 06:11 PM
  3. No KR, but timing pulled on launch
    By efizjb in forum Gen III V8 Specific
    Last Post: February 6th, 2008, 03:25 PM
  4. pulled tune and no VIN is listed, why??
    By mvvette97 in forum Gen III V8 Specific
    Last Post: January 28th, 2008, 07:14 PM
  5. Timing being pulled, but where?
    By DrX in forum General (Petrol, Gas, Ethanol)
    Last Post: December 17th, 2006, 05:19 PM
