Results 1 to 4 of 4
Thread: Help with MAF calibration
    Apr 2008
    Default Help with MAF calibration
    I have done AutoVE multiple times, and all the ben's are within +/- .01. My AFR was good after returning to closed loop except for lean spikes when coming to a stop (I think when it downshifts) and at idle it was a bit lean. So today I did AutoVE again, and when I was finished I attempted to calibrate the MAF using the ben Map in v 7.5. But I'm a little unclear on how to do this. I left my AutoVE tune with the latest VE table in, and plugged the MAF back in, leaving it in open loop. After logging a bit, the MAF ben MAP showed I needed to adjust down low (where it's normally lean), so I did the copy/paste + multiply. Then I repeated the process, and the ben MAP is closer but still shows I need to adjust up to 5% in one cell down low. But at this point my AFR is very close and I think it might be best to leave it alone. Am I doing something wrong or do I just need to keep going?
    Thanks for any help.
    Dave
    Apr 2008
    mods below
    1999 Z28 A4. Mods: comp XER 228/232 111, dart 225's, LS6 intake, SVO 30#, pacesetter LT's & ORY, SLP d/d, underdrive pulley, TCI 3500 SSF converter. EFI Live, LC-1 wideband.
    After plugging in the MAF, reenable it by setting the fail limits back to stock.
    Then clear the DTC's and verify that P0101, P0102, P0103 don't come back on.
    Apr 2008
    Thanks joecar. I didn't do that. I've been reading the stickies here and found the MAF adjustments thread. Very interesting. I have been trying to get all the surge out of my car by working with the timing, cracker and follower tables. But no matter what I do it's still there at part throttle, light load, and when coming to a stop. Which is why I have reverted back to fueling. Even though it seemed correct, running in open loop without the maf, it's dead on and I have no surging. The car runs great. I suspect the surging is going to return once I re-enable the MAF and return to closed loop. If this is the case, what do you suggest I do? This is a street car and I don't want my tune to change with the weather.
  1. odd Calibration
    By CalEditor in forum General (Petrol, Gas, Ethanol)
    Last Post: September 11th, 2009, 05:38 AM
  2. 02 LC1 calibration using V2
    By waterbug1999 in forum FlashScan V2
    Last Post: May 2nd, 2009, 10:14 AM
  3. speed calibration v7.5
    By Ritch in forum General
    Last Post: April 15th, 2008, 06:13 AM
  4. V2 A/D Calibration - FAQ
    By Blacky in forum FlashScan V2
    Last Post: March 10th, 2007, 10:57 AM
  5. MAF calibration?
    By leres in forum General (Petrol, Gas, Ethanol)
    Last Post: September 5th, 2005, 01:22 PM
