Results 1 to 10 of 11
Thread: Auto Trans & Mafless
    Lifetime Member johnv's Avatar
    Jan 2005
    Default Auto Trans & Mafless
    Hi all,
    Read a post (which I can't find again) which said some MAF air flow error codes had to be diabled with an auto when running mafless or the auto would go into limp mode.
    Is this correct ? if so which ones ?
    Cheers
    John
    Not limp mode, but full shift pressure.
    Look under DTC Max Pressure Enablers.
    Set all MAF DTC options to No, only early VT's had the set to Yes.
    Jan 2005
    Thanks Ross,
    Yes its for a mates 00-VT.
    so if I was to upgrade PCM to a later operating system this wouldn't be necessary ? :idea:
    cheers
    John
    Well, they never seemed to be set to go to full line pressure with the later programs. But if you are going MAF-less then it is worth upgrading to a VX+ O.S simply because you won't revert to the back-up VE table.
    Just remember to copy/paste the VT injector flow table as they were different.
    Jan 2005
    Thanks Ross,
    Yes I was aware that the VT's had different manifold and smaller injectors and will copy and paste injector tables.
    Would an 03/04 300kw auto operating system be the best choice ?
    Quote Originally Posted by johnv
    Thanks Ross,
    No, first, it's a HSV :wink: , second, the 300KW Auto had 3.46 diff gears.
    Oct 2004
    Quote Originally Posted by GMPX
    I've heard on a few occasions, and from a few people that the HSV tunes are not good starting points, but I've never got the reasons.
    Can anyone elaborate on why the HSV's are not good base tunes, and secondly perhaps advise what is a good reference base tune (i.e. Camaro, Corvette etc.).
    Just curious to understand the logic behind it?
    Andrew
    EFILive Crew
    Jan 2005
    Thanks Ross,
    Mates car has 3.46 gears already (sold him mine and I put 3.91s in) so would an operating system from a non mafless car be a better start point ?
    Jan 2005
    Thanks Ross,
    Mates car has 3.46 gears already (sold him mine and I put 3.91s in) so would an operating system from a non mafless car be a better start point ? any sugestions ?
    Thanks Ross,
    I saw a std 300KW Auto pull 220KW on a dyno pinging all the way....., you could use the base program from one but you would be better off copying the std Holden spark maps in and go from there. At least the trans stuff would be already sorted.
  1. MAFless??????
    By Rvettej in forum Gen IV V8 Specific
    Last Post: June 25th, 2021, 12:20 AM
  2. Going MAFLESS and O2 less
    By The Alchemist in forum E37, E38 & E67 PFI ECM's
    Last Post: February 12th, 2008, 09:08 AM
  3. Auto Trans & Mafless
    By johnv in forum General (Petrol, Gas, Ethanol)
    Last Post: August 25th, 2005, 09:27 AM
  4. mafless/pcm
    By zrx1200 in forum General (Petrol, Gas, Ethanol)
    Last Post: January 25th, 2005, 01:48 PM
