I saw a std 300KW Auto pull 220KW on a dyno pinging all the way....., you could use the base program from one but you would be better off copying the std Holden spark maps in and go from there. At least the trans stuff would be already sorted.
Ross[/quote]
Ross,
I'm only realy interested in a tune file with a desent set of timing tables to start out with , everything else is easy enough to set up to suit .
Have been using HSV 250 kw timing tables for a base tune (I usually don't see any Knock retard with this table unlike other HSV tables :evil: )
Cheers
John
