Page 1 of 6 123 ... LastLast
Results 1 to 10 of 51
Thread: E38 Pid selection
    Lifetime Member johnsZ06's Avatar
    Sep 2003
    Default E38 Pid selection
    The PID selection for the E38 seems somewhat limited compared to what was available for my C5.
    Can someone post up a PID selection so I can compare? Perhaps I'm not using the right PCM serial #.
    Sep 2003
    No one out there willing to help out a brutha?
    How many do you have to select from? Off the top of my head I would have thought a couple of hundred would show. Certainly all the main PID's you would need for tuning are there.
    Is there a specific thing you are after that your C5 had?
    Sep 2003
    I don't have the option to select any PIDs under "Air" or "O2". SO I can't log MAF, DYNAIR. Can't see if the O2s are switching.
    I don't know what I'm doing wrong. I had a good understanding of how things worked with my C5 PCM and V1.
Name:	pid selection.JPG
    Change the 'System' drop down list to show all, currently it is only showing DMA PID's for the E38.
    Sep 2003
    Switched to "All" and the list is exatly the same.
    The only PID categories which show anything available are "E38", "Performance", and "External".
Name:	All PID selection.JPG
    Sep 2003
    When I select "Default Imperial PID" list, "All", you can see what PIDs are valid.
Name:	Default Imperial PIDs.JPG
    Sep 2003
    And why does it say I have 22 PIDs selected when it clearly shows 4.
    BTW, this is the rest of the above selection after I scrolled down.
Name:	Default Imperial PID selection 2.JPG
    Did you try to force a PID revalidation?
    Connect scantool to ECM then Shift+F2.
    Sep 2003
    No, I'll try that tonight.
    Thanks Ross.
  1. lm-1 pid selection wants lc-1
    By louis in forum General (Petrol, Gas, Ethanol)
    Last Post: June 10th, 2008, 12:11 PM
  2. PID selection???
    By 10secvette in forum Gen IV V8 Specific
    Last Post: January 6th, 2008, 04:29 PM
  3. pid selection
    By Dale in forum Vortec V6/V8 Specific
    Last Post: November 21st, 2007, 02:55 PM
  4. PID Selection
    By Whodunnit in forum LL8 4.2L In-Line 6 - P10 PCM
    Last Post: August 22nd, 2007, 07:34 AM
