Page 1 of 4 123 ... LastLast
Results 1 to 10 of 35
Thread: L76 4L80e AFM
    Aug 2007
    Default L76 4L80e AFM
    Working on getting AFM going on a retrofit L76 with 4l80e in a Nissan Patrol, problem is it won't turn on via software. I did put a manual trans OS in and the AFM was active but would not turn off so I know the mechanical side works and am confident the wiring is too.
    I think the issue may be that that activation tables all revolve around a 6 speed auto, and I have a 4 speed auto. I think this is why it activated and wouldnt turn off when I installed the manual tune.
    Anyone have a stock L76 auto tune I can try?
    All suggestions welcome.
    Cheers
    Joel
    So with a manual tune the engine was in 4cyl mode always?
    I have a .tun file for a 07 K1500 with AFM and 4spd auto, OS is 12612291.
    Lifetime Member limited cv8r's Avatar
    May 2005
    from VZ thunder ute
    Apr 2008
    Default updated tun files
    Hi Ross
    the 12612291 is an update from the 12605897 I was looking for. If you could also email it to haraldschoener "add" yahoo.de
    Thx a lot
    The most actual .tun file for that (LMG) to be 12614088 were they did changes to the E85 calculations..
    I could not find additional info on updates for the AFM, sorry
    If nobody has done it before, somebody has to do it....
    1997 Tahoe 2dr 4WD
    2002 Alfa Romeo Sportswagon 2.0 JTD
    1982 Deutz Intrac 2004A
    2003 friesian Horse " Henry"
    Aug 2007
    Thats correct Ross, even when the activate switch was off.
    Can you e-mail me that file to try?
    jbbottom@bigpond.com
    Joel
    File below -
    Aug 2007
    Thanks Ross,
    Unfortunatly that Cal dosen't run. I had the same issue with the VZ Thunder Cal. I have tried turning VATS off, yet it isn't in the file I was running. I am going to go through all the diagnostics and make the switches the same as the Calibration that does run, even though th AFM dosent. I started with turning of the CAM position solenoids P0010 to P0014, P0615, P0663, immobilizer and start relay control circuit(not reported). I'll work through them all as yet I've nothin'. Scan tool shows RPM and other sensors seem to read correct. Back to it tomorrow but always open to ideas.
    Cheers
    Joel
    So it just cranks or not even that?
    Aug 2007
    Yep, it cranks, the scan tool shows injection ms, RPM and the coils are on yet there is no spark and with a noid light, no injection pulse. I changed all the DTC values to match the Cal that was running in the car with no sucess, I though their may be an issue due to the missing modules, ABS etc as this engine is in a Nissan Patrol with only a TCM. I think its something in the software not available to me to modify. This is the Cal that works in the car. I have had to do a full reflash over the boot block each time, no problems so far.
    Cheers
    Joel
    Aug 2007
    Any ideas Ross???
  1. 4L80E TCC problem
    By Arnoldi in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: March 19th, 2010, 10:26 AM
  2. 4l80e help
    By da69fishman in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: December 9th, 2008, 11:21 PM
  3. 4L80E low rpm shifts
    By pullincrazy88 in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: September 16th, 2008, 01:27 PM
  4. spertech m6 to 4l80e
    By Kilerta in forum Gen III V8 Specific
    Last Post: June 27th, 2008, 01:50 PM
  5. Speartech m6 to 4l80e
    By Kilerta in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: June 25th, 2008, 08:38 AM
