There are 2 engines in question here and 2 ECU's also.
The LSJ was the 2.0L supercharged engine that made 205 HP and 205 TQ under perfect conditions and the LNF is a 2.0L Direct Injection VVT Turbo engine that makes 260 HP and 260 TQ very readily.
ZL1Killa your friend's 2006 is a M62 supercharged LSJ and those numbers are about on par with what a highly modified CobaltSS/RedLine puts out. While the M62 is the newest generation blower it just can't do much more for the engine than make heat as pressure is increased. The whole system is VERY dependent on a cool charge and it just isn't easy with a roots blower in such a tight package - part of the reason why he is running methanol injection - which in my opinion is a band-aid covering up a puss infused staff infection.
Yea, there are here and there stories about bigger numbers, but in each case it's followed by an engine rebuild or constant problems.
The LNF starts out at 260 HP/TQ and as soon as more tuning comes around will excel from that point to well north of 300 HP.
I have had both engines on the dyno for extended testing as a potential aviation engine and must say that while I like them both I prefer the LNF.
