Results 1 to 2 of 2
Thread: Boost Timing Table
    Default Boost Timing Table
    Is there a Boost timing table for the E40 COS that im not Finding somewhere?
    There isn't, however, you can use B5112 to do the job. Given that whilst in boost you will be in PE mode just figure out what EQ ratio the PE is at and then pull the timing out in that table.
  1. DSP5 No timing or Boost
    By Truckguy in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: February 5th, 2010, 03:17 AM
  2. need to retard timing under boost
    By JOHNGEAR in forum Forced Induction and Nitrous Oxide (N20)
    Last Post: November 8th, 2008, 02:07 AM
  3. 2/3 Bar Tuning: Boost Timing Table ?
    By Earl H in forum General (Petrol, Gas, Ethanol)
    Last Post: May 11th, 2008, 01:03 AM
  4. Boost timing PID?
    By TNT76 in forum Forced Induction and Nitrous Oxide (N20)
    Last Post: June 24th, 2007, 08:52 PM
  5. Boost Timing Table
    By marcink in forum Custom Operating Systems
    Last Post: April 24th, 2007, 08:27 PM
