Results 1 to 9 of 9
Thread: Change Engine Oil Light?
    Lifetime Member 87gmc's Avatar
    Apr 2004
    Default Change Engine Oil Light?
    anyone have a problem when doing a reflash of the PCM with the change engine oil light coming on? I have reflahsed my 99 and 01 and both after the flash change engine light came on.
    Sep 2003
    Yes i did and i just reset it and called it a day
    Larry - HumpinSS
    Jan 2005
    the only time that has happened to me was during an OS upgrade. Reset the light and all was well.
    Lifetime Member SS2win's Avatar
    Feb 2005
    key on, engine off, floor it 4 times to clear it.
    2001 Camaro SS
    EFILive Custom OS3
    Apr 2004
    I was just making sure i wasnt going crazy. I know they were getting close to oil change just didnt think it was that close LOL
    Has been noted a few times now, strange, we are 'supposed' to be resetting them after a full flash....will look into it.
    If anyone wants to do us a BIG favour, can they please send me a tun file after a flash with the light on and one with the light off after the reset.
    I will double check what my bench PCM's do.
    Jun 2005
    Quote Originally Posted by GMPX
    I've put quite a few miles on mine (2 oil changes and more than 20 flashes) and have yet to see the change oil light. Usually, I see it by 3500 miles or so when I haven't flashed the pcm (spirited driving plays a factor). It's now been close to 5000 miles and no light.
    Quote Originally Posted by SSpdDmon
    It will only occur after a full flash.
    Nov 2003
    Default Re: Change Engine Oil Light?
    Quote Originally Posted by 87gmc
    I had the same problem a couple of times.
    Bill
    2011 Camaro 2SS/RS L99 RJT
    VMax Ported RJT Throttle Body
    Gorilla Wheel Lock System;
  1. Check engine light/No code?
    By Brad-06-Dmax in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: January 14th, 2010, 05:25 AM
  2. Engine light again...third time
    By goldbergv95 in forum LL8 4.2L In-Line 6 - P10 PCM
    Last Post: October 8th, 2009, 10:32 PM
  3. My engine light just pop out!
    Last Post: January 31st, 2009, 03:02 PM
  4. check engine light after pcm swap ls1
    By Adam Calley in forum General (Petrol, Gas, Ethanol)
    Last Post: February 3rd, 2008, 07:54 AM
  5. check engine light ?
    By Boost in forum General (Petrol, Gas, Ethanol)
    Last Post: March 14th, 2007, 02:22 AM
