Results 1 to 4 of 4
Thread: threw a p0171
    Jul 2008
    Default threw a p0171
    First i'm brand new to efi{feul trim lean bank 1}just checked both banks as follows-bank1 25=min-25.8,avg-25.8,max25,bank2-min-38.3,avg-38.3,m ax0.0,anybody got any suggestions,also looked at duty cyle,bank1 {1145}bank2{1082}this is 98 camaro ls1,only mods lid,gear,catback exhaust
    Jan 2005
    Welcome to the forum birdman!
    Is that a -25 or a +25 on bank1? And bank2 -38 or +38?
    Sounds as if you may have a failing injector or dead coil pack. As an easy test, you could swap the coil packs from bank to bank, zero your trims and DTC's and run a new log. If the problem doesn't move to bank 2, then I'd try swapping the injectors from bank to bank to see if the problem moves.
    Jul 2008
    these are neg-for both
    Jul 2008
    02 sensor{sensor1} was the culprit
  1. P0171 and P0174 codes. Please help
    By JoshH in forum E37, E38 & E67 PFI ECM's
    Last Post: November 3rd, 2009, 05:23 PM
  2. P0171, P0174 Banks 1,2 lean
    By limited cv8r in forum General (Petrol, Gas, Ethanol)
    Last Post: September 5th, 2006, 08:49 PM
