Hey guys,
I've got a 2006 LBZ engine, and lately I've had a DTC come up for an engine underboost code, and I'm thinking there's no way it can be underboosted....I've turned the turbo up a pretty fair amount and i'm not even cranking enough fuel to blow smoke when it kicks down yet
Also, looking at the tables for desired boost w/EGR off, at 800 RPM's the desired boost levels range from about 14-17 lbs of boost in my particular tune depending on altitude, and according to my log file the truck idles (700RPM) at about 15lbs of boost....my gauge shows the truck idling between 2-4lbs of boost...which one is right? What kind of boost pressures are some of you guys reading on your gauges at idle?
Here is my log file...starts with idle, then a couple revs, and then take-off
