Results 1 to 2 of 2
Thread: LLY MAP Limit?
    Lifetime Member Cougar281's Avatar
    Jan 2006
    Default LLY MAP Limit?
    Is the MAP sensor capped? The highest value I've seen in my logs appears to be exactly 37psi (about 23psi boost), but I know I've seen higher than 23# on my boost gauge, which I think reads a few PSI low, and the boost tables call for as much as 44.
    Jan 2006
    Default Soot and heat
    Replace your MAP sensor. Let me know if you need one.
    The LLY uses the same LB7 sensing platform to now regulate boost. Soot has rendered many of these in error.
    Your observation with the gauge illustrates the LLY heat thermal feedback issue also.
    When you log data, are your vane maximums being attained? I am describing false underboost readings leading to turbo overspeed and overboost.
    Custom Tuning Services
  1. 100 log limit????
    By hquick in forum General
    Last Post: February 4th, 2009, 08:08 AM
  2. RPM limit
    By IdahoRob in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: November 7th, 2008, 05:41 PM
  3. Is there a limit?
    By horsehaulin in forum General (Diesel)
    Last Post: June 16th, 2008, 08:28 PM
  4. Limit WOT with ETC ???
    By Ninety8C5 in forum General (Petrol, Gas, Ethanol)
    Last Post: May 18th, 2008, 03:08 AM
  5. HP limit?
    By 80superbu in forum General (Petrol, Gas, Ethanol)
    Last Post: April 1st, 2006, 11:00 AM
