Chuck, we've been here before, remember you said something about you were fed up with the EFILive software telling you that you can't full flash certain GTO's with new OS's? so you did it with HPT and it killed it!. Again that is the reason, we check to make sure you won't kill the ECM by doing it, just cause we're nice guys
I was not aware that TIS killed them too.
Hey, don't blame the GTO, the ECM is made in the US of A !, Delphi must have sent us all the old crap they didn't want to fit in the 06 Corvette
Currently it would require a 100% flash, meaning the Bootblock, OS and calibrations to cure this problem. EFILive and everyone else does not touch the bootblock as it is supposed to be always recoverable if you don't flash that. At some stage we should add the option to do a 100% write of the flash.
