KR map for E67?
I'm trying to figure out how to create a KR map for an E67. The trouble I'm having is that in the scan tool the column axis's link for the spark table is {E38.APCYL_DMA}. I don't think I can log E38.APCYL_DMA because its not supported for the E67. I was trying to set the map up with GM.DYNAIR_LS2 but that doesn't seem to work. I'm obviously trying to learn how to set up maps, any ideas?
Jay
I got it to work by logging {APCYL_DMA} in my column axis, also had to change the cal_link file. Thanks to ChipsbyAl
- You may not post new threads
- You may not post replies
- You may not post attachments
- You may not edit your posts
Forum Rules
