Results 1 to 5 of 5
Thread: Unable to view adaptive shift cells
    Oct 2007
    Default Unable to view adaptive shift cells
    I'm not able to view my adaptive shift cells with my scan tool for my LMM. Is there not support for it? I thought it was working before but It's is grayed out and I can't select it. Thanks!
    It was possible to view them as a list for the LB7-LLY TCM but not the LBZ-LMM. It is a planned feature add in as soon as we can.
    Oct 2007
    Thanks Ross, any timeframe that it may be included?
    I should have added that last part in.
    Time frame, maybe by the end of August, we have a number of updates (non critical) that we need to add in to the software, it will go in with them.
    Oct 2007
    Ok thank you
  1. How to select mutliple cells in a row to smooth?? but not all of the cells.
    By 2010 Bumblebee in forum General (Petrol, Gas, Ethanol)
    Last Post: April 29th, 2010, 02:34 PM
  2. Adaptive Shift Times 4l80e + HD2
    By 2500ak in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: January 26th, 2010, 08:22 AM
  3. Shift Times, Line Pressures, Adaptive Learning -- AGAIN!
    By arubenstein in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: July 16th, 2008, 11:09 AM
  4. Disable adaptive shift learning after Shift Kit Install
    By BlackGMC in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: January 24th, 2008, 04:49 AM
  5. adaptive shift learning
    By dbaxter_ss in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: May 5th, 2005, 06:33 AM
