Results 1 to 9 of 9
Thread: parameters not updating during emulation
    Lifetime Member limited cv8r's Avatar
    May 2005
    Default parameters not updating during emulation
    Has any had any trouble with some parameters not updating or making any change to the way the tune behaves whilst emulating? I have had trouble with speedo changes not making any difference at all, also the other night, changed rev limiter with no effect. From memory I think I had to reinstall my original PCM and change and flash parameter changes for speedo calcs to work.
    Jul 2007
    Quote Originally Posted by limited cv8r View Post
    I have not had an occurence when it did not update--that I know of.
    Make sure you click the REAL TIME button, not just the emulation mode of use.
    07 Silverado DMax Classic
    02 Z06 LS3 416, 805rwhp, TFS245, Wiseco, Callies Crank/Rods, Iskendarian Lifters, Crower Rockers, FAST102/90, ATI Damper, 1-7/8 Kook's LT, QkTime Shield,Tolle-Fab 8pt
    Old Engine: 1/4mile = 9.6/146 New Engine:?
    EFI Live Tune/Scan v7.5.27, EFI Live Scan and Tune v8.2.23, build 276, BootBlock 2.07.06, FirmWare 2.07.52, 512K RoadRunner (12.14.R), Innovate Serial LC2x2
    COS5/12212156 For 2002 Z06 Manual Vette
    May 2005
    I understand how the RR works, just statng a couple of strange glitches I have come accross.
    Some things that only get looked at on key on and then stored in RAM do not get updated in real time as the PCM doesnt look at that variable again.
    Make the changes , then do a full write and key off , restart and all will be updated.
    May 2005
    Are there any general areas where these parameters are? eg. speedo,system, etc or are they all through the calibration?
    Fixed variables that cant change or be part of a lookup table are normally loaded as the pcm intialises that way it saves looking at them later on in the routines and frees up more processing time for the cpu. There are quite a few that are laoded on startup througout the cal .
    May 2005
    Ok, thanks for that.That should save me some confused looks and a lot of swearing.
    Lifetime Member JezzaB's Avatar
    Nov 2006
    Ive had some issues with VIN numbers beng lost and 000000000000 being written. I have to flash back in a stock OS then the custom OS and sometimes it comes good. This only happens now and then.
    When 000000000000 is in there I cant change it and it can't scan all of the PID because the scan tool doesnt know what to look up.
    Oh well..
    Jez
    Feb 2008
    Jez that tune we put in the RR last nght has that 0000000000000000 vin ......
    I ate my bowl of Aussie rice for dessert, Main course was imported rice...
  1. Flash vs. Emulation
    By Stealth97 in forum RoadRunner Real-Time PCM Emulator
    Last Post: January 30th, 2009, 06:18 AM
  2. RR not updating.
    By John02SS in forum RoadRunner Real-Time PCM Emulator
    Last Post: November 28th, 2008, 12:47 PM
  3. Updating
    By Eddysel in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: March 26th, 2008, 11:53 AM
  4. Help with updating os
    By cmitchell17 in forum General (Petrol, Gas, Ethanol)
    Last Post: October 14th, 2007, 10:57 AM
