Page 1 of 3 123 LastLast
Results 1 to 10 of 24
Thread: EFILive 7.3 pre-release software has been updated - again
    Default EFILive 7.3 pre-release software has been updated - again
    Download the latest EFILive V7.3 pre-release 003 software here:
    http://www.efilive.com/downloads/downloads_730.html
    A complete CD-based software installation package will be available soon.
    Please post any issues in this thread.
    The 003 update, was to apply a work-around to EFILive so that EFILive can read PCMs reflashed by GM's TIS programming system which 50% of the time delete the PCM's hardware number and VIN.
    EFILive Distributor dfe1's Avatar
    Jan 2005
    I can't unzip cal_03.zip. I've tried on two different computers and get a message that the file is invalid or corrupt. All other files unzip fine.
    Quote Originally Posted by dfe1
    Fixed.
    Lifetime Member mistermike's Avatar
    Dec 2003
    Default Full flash required?
    If I'm on a custom O/S and the custom .tun file has not been updated (as it appears mine hasn't 0411003), is it still necessary to full flash the custom O/S in dead poll and re apply the tune?
    World's First Twin Screw Pontiac GTO
    2004 GTO. Blown H/C 408, stage 3 keyboard, billet tires
    2017 Chevy SS with dead hooker is spacious trunk
    2014 Chevy Cruze. MPG queen with my balls in spacious glove compartment.
    www.aussiemotive.com
    Default Re: Full flash required?
    Quote Originally Posted by mistermike
    No updates have been made to the *.tun files - you do not need to do a new full reflash. The new calibrations will be available simply by downloading and installing the matching *.cal file for your operating system.
    The *.tun files will only ever be updated if/when Ross adds new features to those operating systems.
    Dec 2003
    Sweet! So I should just be able to fire up the scanner for a CASE learn to clear up the little CKP issue?
    Also, the new "smooth / fill" feature when copying maps intrigues me. I wonder how good it might be in the early stage of BEN mapping where you're unable to populate as many cell as you might have liked to. I've got a boosted VE table that needs a chain saw with multiple BEN logs because I started out so high. It's difficult to fill that sucker up on a public highway.
    Yes
    That's exactly what it was designed for
    Set the smooth weight inthe MAP property window to 100.
    Dec 2003
    Beautiful!
    Jan 2005
    I like it!
    The download page does have a typo (or my drunk eyes aren't reading it right) on step 5
    Sep 2003
    Yup after comming home from work i realized the values i seen were from a log that was allready close so it didnt need to work to much to help with surrounding values.... 8)
    EFILive - The Single version of the Truth
    Larry - HumpinSS
  1. Software issues with build 99 pre release...
    Last Post: January 18th, 2010, 04:25 AM
  2. Replies: 22
    Last Post: January 8th, 2007, 02:15 PM
  3. EFILive 7.3 pre-release software is now available
    Last Post: August 18th, 2005, 11:51 PM
