Yep, and steps 10, 11, 12 and 13 were wrong as well. All fixed now.Originally Posted by TAQuickness
After opening a second file to do a compare, the compare icons don't appear on the screen. They're on the pull-down Calibration menu (Ctrl+ 4, 5 and 6)and function properly, but previously, they showed up on the page for whatever table was open. Software problem or user problem?
just finished installing -002. Will "EFILiveV730_Pre-release_003.zip" suffice to get us updated from 002?Originally Posted by Blacky
Disregard, apparently fixed by pre-release 3 or by 03 cal file.Originally Posted by dfe1
In 1, it says to download EFILive_stock_cal_20050824.zip and also, "All 11 files from this page." This results in downloading EFILive_stock_cal_20050824.zip twice.
The build numbers in 13 appear to need updating, for example obdiiV7.dll says 412 but after installing this update I have 417.
Yes!Originally Posted by TAQuickness
You're right about downloading twice - I'll fix the instructions.Originally Posted by leres
And I'll update the build numbers.
FRom the Pre-release_003 Download page:
Are these the updated build numbers?After the pre-release has been installed, you should check that the following version numbers are displayed in the Help->About window:
Tuning Tool V7.3.0 (Build 268)
Scan Tool V7.3.0 (Build 277)
obdiiV7.dll: V7.3.0 (Build 412)
I updated from 001 -> 002 -> 003 and I'm showing Build numbers 273, 281 and 417, respectively.
joel
I can still access alternate cals from the menu or with crtl 4/5, but I no longer see the buttons for ALT and CAL.
However, It now seems to let you view a standard and custom O/S based tune side by side. My taskbar thanks you.
World's First Twin Screw Pontiac GTO
2004 GTO. Blown H/C 408, stage 3 keyboard, billet tires
2017 Chevy SS with dead hooker is spacious trunk
2014 Chevy Cruze. MPG queen with my balls in spacious glove compartment.
www.aussiemotive.com
One thing that confused me is that the flash options are listed as:but since .tun files contain calibration and operating systems (see this post) shouldn't the first option be "Read PCM operating system and calibrations?"Read PCM calibrations
Program PCM calibrations
Program PCM operating system and calibrations
