I need to calibrate a MAF on a L76, can some one point me in the right direction for a thread or tut.... please
Shane
Shane
I ate my bowl of Aussie rice for dessert, Main course was imported rice...
These might get you started, you will have to change the data parameter to whatever you need in the edit map properties tab.
thanks, what do you open the files in... when click on the unzipped file it says no program available...
it is just a zip file. if you need I can re-upload the files, but I will have to change the extension as it wont let me upload .map files
all good will see if i can, not a great understanding of computer file systems... I will learn :lol:
I see you unzip the files into the map section in the EFI live folder okay makes sense now...
shane
only if i can work out how to apply the maps... lol... never done this before.. never even autoVe'd as i am lazy and have a RoadRunner....
Swingtan we need a point by point instruction manual...... PLEASE....
Tuning the MAF is the same concept as AutoVE or the RTACS of the VE. Get your self in open loop, apply the BEN factor.
