Page 1 of 3 123 LastLast
Results 1 to 10 of 21
Thread: My V1 stopped working!!!!!
    Senior Member RandyWS6's Avatar
    Jan 2005
    Exclamation My V1 stopped working!!!!!
    To day I did some logging and it worked fine, The i done a re flash on the fan settings and it worked fine ,But after i close out i reopened up the scan tool it wound not connect , on the black box only the OBD & USB lights were flashing. And would get a error code 31 could connect. I have Predator hand held and plug it in and it worked fine. This is the first time Ive had any problems with the V1 and Ive own it since 2003 . Ive tried every thing restart my laptop , unplug the usb cable and even tried it on my other laptop that i have for a backup and it does the same thing. Does the V1 has any kind of warranty ? I need to send it back to get it fix ASAP !!!!!!
    2000 WS6 TransAm-M6 LS3 forged 422 cid. 4L80 FMVB ,4:22 Ford 9"-35 spline axles
    2014 C7 3LT-Z51 Corvette Stingray M7 , A&A Supercharger , Kooks 1-7/8" long tubes & X Pipe 615 rwhp & 560 rwtq
    http://community.webshots.com/album/259987907DcztOG
    Jan 2007
    Have you emailed Paul?
    Howard
    DUCT TAPE.
    98 K1500 'HOLDEN' Suburban.
    Jan 2005
    No i havent, How do i get his e-mail address ?
    Jan 2005
    PM Blacky or support@efilive.com
    Jan 2005
    Thanks.
    Check the cigar lighter fuse before you send it back.
    Jan 2005
    I know this is a stupid question, but what does the cigarette lighter haft to do with it? And I did check all the fusses. But i will check and see if there power coming out of it.
    Jan 2005
    the OBD2 port and cigarette lighter are on the same fuse.
    Jan 2005
    The hand held that i have works just find, and it gets its power from the OBD2 port also. Im at work right now but when i get home ill check it any way.
    I pm'd tech support.
  1. DSP 5 not working
    By minytrker in forum Duramax LB7
    Last Post: March 9th, 2010, 09:22 AM
  2. C.A.S.E not working
    By uaesands in forum E37, E38 & E67 PFI ECM's
    Last Post: September 25th, 2009, 01:38 AM
  3. E40 DMA Not Working
    By Forcefedperformance in forum Gen IV V8 Specific
    Last Post: July 27th, 2008, 04:50 PM
  4. V2 not working!!!!!
    By robertleeii in forum FlashScan V2
    Last Post: August 25th, 2007, 11:28 AM
  5. V2 not working with win 98
    By Buzzard in forum FlashScan V2
    Last Post: April 6th, 2007, 09:07 AM
