Results 1 to 5 of 5
Thread: Turbo & Tuning
    Jul 2005
    Default Turbo & Tuning
    Got this from Innovate site, anyone done any exprerimenting in this area, particularly what is said in the ** paragraph?
    Lonnie
    Spark Timing Myths Debunked
    A widely-held myth is that maximum advance always means maximum power. Here’s what’s wrong with this thinking:
    The spark plug ignites the mixture and the fire starts burning. The speed of this flame front depends on the mixture, this means how many air and fuel molecules are packed together in the combustion chamber. The closer they are packed together in the same volume, the easier it is for the fire to jump from one set of molecules to the other. The burning speed is also dependent on the air-fuel-ratio. At about 12.5 to 13 air-fuel-ratio the mixture burns fastest. A leaner mixture than that burns slower. A richer mixture also burns slower. That's why the maximum power mixture is at the fastest burn speed. It takes some time for this flame front to consume all the fuel in the combustion chamber. As it burns, the pressure and temperature in the cylinder increases. This pressure peaks at some point after TDC. Many experiments have shown that the optimum position for this pressure peak is about 15 to 20 degrees after TDC. The exact location of the optimum pressure peak is actually independent of engine load or RPM, but dependent on engine geometry.
    Typically all the mixture is burned before about 70 deg ATDC. But because the mixture density and AFR in the engine change all the time, the fire has to be ignited just at the right time to get the peak pressure at the optimal point. As the engine speed increases, you need to ignite the mixture in the combustion chamber earlier because there is less time between spark and optimum peak pressure angle. If the mixture density is changed due to for example boost or higher compression ratio, the spark has to be ignited later to hit the same optimal point.
    If the mixture is ignited to early, the piston is still moving up towards TDC as the pressure from the burning mixture builds. This has several effects:
    The pressure buildup before TDC tries to turn the engine backward, costing power.
    The point where the pressure in the cylinder peaks is much closer to TDC, with the result of less mechanical leverage on the crankshaft (less power) and also causes MUCH higher pressure peaks and temperatures, leading to knock.
    **Many people with aftermarket turbos don't change the spark advance very much, believing that earlier spark creates more power. To combat knock they make the mixture richer. All that happens really then is that the mixture burns slower and therefore hits the peak pressure closer to the right point. This of course reaffirms the belief that the richer mixture creates more power. In reality the flame front speed was adjusted to get the right peak pressure point. The same result (with more power, less emissions and less fuel consumption) could be achieved by leaving the mixture at the leaner optimum and retarding the ignition more instead.
    Turbo charging or increasing the compression ratio changes the mixture density (more air and fuel molecules are packed together). This increases the peak pressure and temperature. The pressure and temperature can get so high that the remaining unburned mixture ignites by itself at the hottest part in the combustion chamber. This self-ignition happens explosively and is called 'knock'. All engines knock somewhat. If there is very little unburned mixture remaining when it self-ignites, the explosion of that small amount does not cause any problems because it can't create a large, sharp pressure peak. Igniting the mixture later (retarding) causes the peak pressure to be much lower and cures the knock.
    The advances in power of modern engines, despite the lower quality of gasoline today, comes partially from improvements in combustion chamber and spark plug location. Modern engines are optimized so that the flame front has the least distance to travel and consumes the mixture as fast as possible. An already burned mixture can no longer explode and therefore higher compression ratios are possible with lower octane fuel. Some race or high performance engines actually have 2 or three spark plugs to ignite the mixture from multiple points. This is done so that the actual burn time is faster with multiple flame fronts. Again, this is to consume the mixture faster without giving it a chance to self-ignite.
    Higher octane fuel is more resistant to self-ignition. It takes a higher temperature and pressure to cause it to burn by itself. That's why race fuels are used for engines with high compression or boost. Lead additives have been used, and are still used to raise the self-ignition threshhold of gasoline, but lead is toxic and therefore no longer used for pump-gas. Of course a blown engine is toxic to your wallet.
    2002 EB Coupe, MN6
    Xtreme TTi Twins @8psi, Dual A-pilar gauges - fuel&boost, x-pipe, Borla Straight Twin Oval from Cats on back, Hurst Short Throw, CCW 3 piece rims - 18x9.5/275-35 and 18x11.5/335-30 Pilot Sports
    Drive it like you stole it!!!!!
    Jul 2005
    If the above is true and it seems reasonable to me, then the only way to really tune for this phenomenon would be on a dyno, runing 12.5-13:1 AFR on a WOT run, monitor power output, make a timing change (retard) and run again, make timing change and run again till the the power drops off then back up one step for optimum timing at WOT.
    But to do this we would have to use the CALC PID that someone posted a week or so ago to show actual timing, not programed timing (wish I could find that post). If I remember correctly, there are several dynamics that can affect +- the actual timing that is sent to the coils. Then you have to look into any changes that were made to your programed timing and see how to minimize those affects, then adjust programmed timing accordingly and equally +-.
    But once someone knows what the actual timing is for an LS1, under specifc boost, that would work for all LS1 with the same boost. At least till you change an engine dynamic or boost.
    This almost sounds like a catch 22 that has an out that is a long way off in the distance. But any effort someone put into this would pay off in HP/TQ.
    What do you think... :?:
    Lonnie
    2002 EB Coupe, MN6
    Jul 2005
    Okay, lets take this a step further.
    Couldn't we use the CALC PID that is posted in TIPS & TRICKS: Calculate Instintaneous Net HP, as a measurement stick to perform this process? Adjust timing for max power per the CALC PID?
    Lonnie
    2002 EB Coupe, MN6
    Jul 2005
    Okay, posted this in another forum and get this, a guy who has been to EFI 101 and Advanced says that is pretty much what they teach.
    Also came to me last night that this is just what the PCM does also: The PCM encounters knock it retards the spark to eliminate it, not more fuel.
    Now that CALC PID for spark advance and its many variables becomes even more important. Darn I wish I could find that post, did several searches and still nothing...
    Lonnie
    2002 EB Coupe, MN6
    Quote Originally Posted by lplott
    Interesting thing from EFI101, when the PCM actually detects the knock it's too late, in other words, the process of knocking began before the PCM heard it.....I'm still not making sense!!.
    Lets say the log showed knock at 3500RPM, the process actually began earlier (maybe 3200) so you might be better to visit that area of the spark map (or fuel).
    I personally wouldn't use any of the PCM's own calculated PID's for any sort of measuring (like Torque etc), it's only 'calculated' afterall and calculations need numbers, whats to say the numbers are even close when you modify the engine from stock....and example, on an ETC car with a cam, running without a MAF they will torque limit before the actual torque output of the engine would actually be because it's own calcualtions get messed up.
    No different to the Cat Converter protection routine, it's only an estimated temp.
  1. Turbo Tuning Help
    By jckleewein in forum General (Diesel)
    Last Post: August 30th, 2009, 06:11 PM
  2. turbo 5.3 silverado tuning
    By kostelacd69 in forum General (Petrol, Gas, Ethanol)
    Last Post: March 2nd, 2009, 08:01 PM
  3. sts turbo tuning
    By xAustin in forum Vortec V6/V8 Specific
    Last Post: September 6th, 2007, 07:39 PM
  4. AutoVE tuning with turbo
    By WicketMike in forum Forced Induction and Nitrous Oxide (N20)
    Last Post: September 3rd, 2006, 09:22 PM
  5. Turbo Tuning
    By WicketMike in forum General (Petrol, Gas, Ethanol)
    Last Post: January 21st, 2006, 07:43 PM
