Results 1 to 3 of 3
Thread: Fuel Problem COS-3 E40
Hybrid View
    Default Fuel Problem COS-3 E40
    We Are having a problem with a 06 GTO going lean for some odd reason and we are having trouble finding out why its doing it....the car is a 6.0 stock bottem end with ETP LS1 Heads,Cam,APS Twin Fuel Pump,60LB injectors,Aeromotive aeromotive regulator and a F1 A Procharger.
    We was making about 5 PSI at 5800 and everything was fine so we changed the pully to make some more boost and now whenever we hit about 5000-5200 rpm no matter how high we make the boost ve numbers it will allways go lean in the same spot. We are watching fuel pressure and not seeing a drop so we are a little confused.
    Could someone please take a look the file and see if we are over looking something?
    Thanks ,Bill
    Bill,
    Have you logged what the Airflow g/cyl is at this point? If 'for some reason' it is dopping a lot you will see the lean spike and probably timing go up too.
    Log the PID GM.APCYL_E40_DMA
    Your right our APC was droping...but why?
    Here is the data log for that car.
  1. Fuel Rail Pressure's relationship to fuel economy.
    By duramaximizer in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: February 28th, 2010, 01:18 PM
  2. using SCAN to diagnose fuel problem
    By Boost in forum Duramax LB7
    Last Post: December 24th, 2009, 06:41 AM
  3. Problem with fuel tables?
    By Sparky8370 in forum Duramax LB7
    Last Post: June 22nd, 2009, 11:28 PM
  4. Fuel Problem COS3 E40
    By Forcefedperformance in forum Custom Operating Systems
    Last Post: August 28th, 2008, 03:20 AM
  5. 05 GTO idle/fuel problem
    By slowhawk in forum Gen IV V8 Specific
    Last Post: March 30th, 2008, 01:36 PM
