Results 1 to 10 of 17
Thread: 2 Questions........
    Junior Member jtaylor111's Avatar
    Nov 2007
    Talking 2 Questions........
    First.....I need to recalibrate my injectors.......Can I do that and how?
    Second.....I have a limping problem a few months back from the P0101 code. Some fixed one of my tunes with a new release. Im wondering how I can get that release so I can fix the rest of my tunes so I can run my AFE air box.
    Recalibrate the Injectors?, are you getting a code or something?
    The MAF issue can be done by remapping {B0802} on an LLY, but I can't find that in the current release for LBZ/LMM, what did I do with it??
    I'll get back to you on that one....
    Nov 2007
    Yes Im getting P268C P268D P268E P268F P2690 P2691 P2692 P2693. Thanks for looking and this for a LMM. Talk with a dealership about recalibrating and it sounds like a long drawed out ordeal. I have my orginal ECM that I messed up where it would take a tune. I didnt have a issuse with this one about the incorrect calibration. I was wondering......a guy on Diesel Place told me to send it to him and he might beable fix it. So I was thinking about might be cheaper to see if he can fix it and use this one as a backup.
    This can be solved with the V2, it will copy the Injector values from the GPM to the ECM.
    Read from Post #14 on in this thread -
    http://forum.efilive.com/showthread....ght=GPM&page=2
    Nov 2007
    I read the link and Im alil confused. F3 then F2 takes me to "Link Options". The F1 option is "Ctrl:" There it dose not give me a "GPM" as stated in the other thread. I only get PCM, ECM, TCM or ECM & TCM. Just wondering where Im getting it wrong in the steps. Thanks.
    2008 GMC Sierra 3500
    46" Michelin XL
    2.5 Rockwells, 4 link and Coilovers
    When was the last time you updated the V2 firmware?, it might be too old and not have that function.
    Nov 2007
    This is the last update I did...... C:\Program Files\EFILive\V7.5\FSProg_V2_4_72.ffw
    46" Michelin XL
    Well now that BBL is out of beta, I would upgrade to the latest bootblock and firmware.
    Nov 2007
    I looked into the BBL. I didnt see a .ffw file.
    46" Michelin XL
    You need to read the .pdf included with V8.1.1, it explains how to upgrade the bootblock (must be done before the firmware) and then use EFILive Explorer to program the new v2.5.19 *.efw file. Cant use the old programmer with the latest firmware.
  1. LMM DSP questions / Power questions
    By Djreversal in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: August 18th, 2011, 08:06 AM
  2. A Few Questions
    By JAHII in forum Gen IV V8 Specific
    Last Post: December 21st, 2009, 05:45 PM
  3. PID questions.
    By DmaxHawk in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: September 23rd, 2008, 10:43 AM
  4. Help.....I have a few questions...
    By WiseGuyZ06 in forum General (Petrol, Gas, Ethanol)
    Last Post: July 10th, 2007, 05:10 AM
  5. Just have a few questions...
    By thosewhohatedmecreatedme in forum General (Petrol, Gas, Ethanol)
    Last Post: September 20th, 2006, 10:40 PM
