Results 1 to 7 of 7
Thread: downloading stock tune ?
    Jul 2008
    Default downloading stock tune ?
    I 've watched nicks downloading tutorial a dozen times now. I hook everything up and efi reads my stock tune. It shows my vin# while reading but, once you turn the ignition off and close out the window it doesn't show the vin # N/A is all i get there. Can some please tell me what I'm doing wrong.
    Jan 2005
    Welcome to the forum CountryBoy. I've PM'd tech support.
    Oct 2006
    I posted this same question last week. Ross said it would not be a problem-and it wasn't.
    I'm pretty sure in older versions of EFILive we didn't store the VIN for the LBZ/LMM controllers in the *.tun file as that info is not read from the controller during a flash upload.
    In later versions, I think the VIN was read using normal Scan Tool commands and then stored in the *.tun file in the meta data section.
    Make sure you are using the latest version. If you are using the latest version (V7.5.4 build 65) please email the *.tun file to me at paul@efilive.com and I'll take a look.
    Jul 2008
    I just got my efi today and have the lateset software for it. I will get my stock tune and send it to you in about 20 mins. Thanks Clinton
    For the LBZ/LMM controllers, the VIN is supposed be saved and displayed each time you load the *.tun file.
    However, there appears to be a bug that sets the VIN to "N/A" after reading the ECM and before saving the *.tun file.
    I have fixed the bug and it will be available in the next update.
    Meanwhile, you can type the actual VIN over the top of the "N/A" and then re-save the file.
    That should make the VIN permanent in the *.tun file.
    Note: it makes no difference what value you put in the VIN field in the *.tun file (for LBZ/LMM controllers), EFILive does not use it.
    It is really only for your reference.
    Jul 2008
    Thanks Blacky. I'll hopefully be flashing my truck tomorrow for the first time with the dpf deleted. Then my off road truck will be code free. Thanks again
    Clinton
  1. Possible stand-alone tune downloading
    By Brian1 in forum FlashScan V2 BB Logging
    Last Post: May 7th, 2009, 09:06 PM
  2. downloading stock tune help!!!
    By weettiddo007 in forum General (Diesel)
    Last Post: May 21st, 2008, 01:35 PM
  3. Need Help! Problems downloading stock tune
    By dodson914 in forum E37, E38 & E67 PFI ECM's
    Last Post: April 6th, 2008, 06:56 AM
  4. downloading stock tune
    By sweetdiesel in forum General (Diesel)
    Last Post: April 9th, 2006, 04:33 PM
  5. Problem Downloading a Stock Tune
    By JrTuner in forum Duramax LB7
    Last Post: January 7th, 2006, 05:32 PM
