Results 1 to 10 of 20
Thread: v2 still only logging for a few minutes..
    Oct 2005
    Default v2 still only logging for a few minutes..
    I am all software'd and flashed up with the latest files from the downloads page. fw_02_05_19
    When BBL I only get maybe 30min max. Normally 10Mb files, today with the new FW only 5Mb or around 20min
    My trip is 2hrs.
    Am I doing something wrong...?
    2014 VF SV LS3 Maloo.
    Lifetime Member Chuck CoW's Avatar
    Feb 2006
    Default Well....similar stuff here too.....
    Quote Originally Posted by ringram View Post
    My trip is 2hrs.
    Hmmmmmmmmmm..... Well, interesting.....I just upgraded to the latest stuff and it seems that with E67 controllers (or maybe can controllers in general) I go logging for 10 to 15 mins and then the EFI LIVE scantool just locks up....
    I'm still connected, but....the screen freezes and nothing happens.....
    Anyone else??
    Chuck CoW
    CoW BOOSTER! Electronic Throttle Enhancement.
    - CLICK HERE NOW FOR MORE INFORMATION! -
    VARARAM, EDELBROCK, AMERICAN RACING HEADERS, BAER BRAKES, BORLA, EFI Live, Magnuson,
    COMP Cams, PROCHARGER, PRO TORQUE, PHADT Racing, INNOVATORS WEST, and more.
    Jan 2004
    I am not upgrading to the latest then if it's doing this again. :p
    I am on the update before the latest and it works fine. Mine was doing this on a couple of the previous updates and Paul fixed it.
    E38/T43 controllers for me.
    Oct 2005
    Yeah mine was doing it on an older firmware, hence why I upgraded! :(
    Not good for doing VE tables.
    Paul Help! E38 here. HSV OS E Series R8
    Jul 2007
    Guys, have you checked the number of PID's you are logging? I can log for a good 25 minutes and end up with a log file of 2MB in size ( E38 ). I've also performed a few extended log sessions where I've turned the engine off and allowed the V2 to enter suspend mode, then restarted the log the next time I've driven the car. Any chances you can post a log from one of these sessions where the V2 has locked up?
    Simon
    Oct 2005
    Its too big to attach to the message, so you can DL it here.
    This is from a 1hr45min log session
    http://www.systemsup2.plus.com/BBL00047.zip
    Jul 2007
    OK, you have a PID count of 19 and a channel count of 25, so I doubt that's an issue. I usually log with 22 PID's and 34 channels with no issues. Was this a log when the V2 hung or a normal log?
    I take it you have checked the Firmware version in the V2?
    Simon
    Oct 2005
    Latest version as noted above squire with a reformatted config file system.
    The copied the files from the new 8.1.1 over and the options.ini as well
    Jul 2007
    Have you tried wiggling the main ODB-II cable to see if there is an intermittent connection? I know with mine that if I wiggle the cable just near the RJ45 plug, the V2 will reboot, indicating a bad connection. You may be getting a bad power feed into the V2, causing it to lock up.
    Junior Member hrthsv's Avatar
    Dec 2007
    Ringman I am using the latest release firmware version 19 same as you and have logged 500km in one day where the car was switched off twice and still got it all on 1 log. Must be something going wrong with your V2. I was logging on E 40 PIDs for Ls2.
  1. Anyone else BBL shut itself down after about 40 - 60 minutes?
    By Jasondt2001 in forum Black Box Logging
    Last Post: August 22nd, 2009, 10:45 AM
  2. Idle after 30 minutes goes rich
    By louis in forum General (Petrol, Gas, Ethanol)
    Last Post: November 24th, 2007, 08:45 AM
  3. fouling plugs every 10 minutes
    Last Post: July 17th, 2006, 01:34 PM
  4. help with logging
    By HioSSilver in forum General
    Last Post: July 8th, 2005, 05:02 AM
