Before I download and install BBL, can I BBL
LC-1 AFR
LC-1 AFR Serial in
Calc PID such as Fuel Pressure AD1
Calc PID such as Bottle Pressure AD2
and Relay Status?
LC-1 AFR
LC-1 AFR Serial in
and Relay Status?
1999 C5 A-4 Convertible
1 of 245 Nassua Blue 99 Vert's, Blackwing, LS6 Intake, 42 # Injectors, Two Stage Nitrous System- Dry and a Wet Plate, EFI Live Scan/Tune V2, 1999 PCM with 2002 COS 5 OS Custom Nitrous Panel.
Maine USA
Jim,
The calc pids are added later when you view the log.
Joe
I can deal with that
SO just log Voltage AD1 AD2 and the usual PIDs as well as Relay Status... Then open the log and add the calc PIDs (Fuel Pressure, Nitrous Pressure, and LC1 AFR).
That will work for me. Looks like I will update now
Maine USA
On the V2 LCD, go into "Settings" (or whatever it is called) and enable the Analog Pids.
