Page 5 of 5 FirstFirst ... 345
Results 41 to 50 of 50
Thread: Afr spikes in BBL only
  1. #41
    Yes, but with the new firmware, I'll email it to you as soon as it is done.
    Quote Originally Posted by vxleather View Post
    okay, you still want the the trace files done this arfternoon???
  2. #42
    Feb 2008
    okay thanks, I might be able to do some loging after all for our trip to townsville over the weekend... okay i am getting a little excited again...
    I ate my bowl of Aussie rice for dessert, Main course was imported rice...
  3. #43
    Feb 2008
    Blacky, I have just uploaded the update you sent... and noticed this again..i remeber in the past you asked us to delete the "settings" folder out of the config file...(cant remeber why) I noticed mine keeps appearing even after I have deleted it...
  4. #44
    FlashScan will recreate it with the install defaults if it is not there. So you should expect it to re-appear after you delete it.
    The only times you would need to delete it are:
    1. When a new firmware is released that uses a different format for the settings file (hopefully that won't need to happen again).
    2. If you want to reset all the settings to their defaults.
  5. #45
    Mar 2004
    My V2 works in Shane's car with the PLX serial setup ok .as soon as we load 8.1 22/6 the problems starts . the update you sent yesterday is showing problems as well , shane is sending the trace file to you . is there a back door to reload pre 8.1 22/6 untill the problems are worked out
  6. #46
    Feb 2008
    Trace file and logs sent last night Paul, ntae thanks for your efforts last night much appreciated.
    Shane
  7. #47
    Senior Member alian's Avatar
    Jun 2008
    I was talking to Alian last night and had a look through his latest log. There was still evidence of WB issues with the log data, though it was a little different.
    With the log file I saw, the WB data would regularly flat line before continuing on again. there were a few spikes, both rich and lean. The spikes in this case only occurred after a time of the WB data flat lining. My thoughts on this are...
    1. Intermittent power supplied to the WB controller.
    2. Intermittent connection in the WB controller to sensor cable.
    3. Intermittent connection in the WB controller to V2 serial cable.
    Of course that doesn't explain why the data seems fine in pass-through mode, unless there is some sort of filtering that occurs in pass-through that id not applied in BBL mode.
    Is there any chance that the A/D filter settings get applied to the serial data when in pass through, but not in BBL?
    All that being said, I'm running a TE unit with the V2 and have only had issues with intermittent connections. Never any interfacing issues.
    Simon.
    Did another log and, sent through to Simon, No spikes or flat lines this time. might have been a bad conection. Will keep an eye on it. Ian
  8. #48
    Jul 2003
    I am seeing this and I am suspecting a sensor timing problem... I will exchange sensors and see... my problem comes on pass thru though...
  9. #49
    Post pics/screenshots.
  10. #50
    Jul 2003
    Here it is... its only at WOT...
    I guess its a sensor issue because there is more "pressure" at WOT than there is at Part Throttle, so...... sensor is having issues... I will try a different sensor tonight...
  1. spikes during shifts??
    By drdarthinvader in forum Gen III V8 Specific
    Last Post: January 9th, 2009, 05:02 PM
  2. Lean spikes commanded vs actual AFR
    By billyjo in forum Custom Operating Systems
    Last Post: January 24th, 2008, 05:58 PM
  3. Question about AutoVE Spikes I am getting
    By Goldfinger911 in forum Gen III V8 Specific
    Last Post: October 14th, 2007, 01:29 PM
  4. Lean spikes
    Last Post: June 2nd, 2007, 04:20 PM
