okay thanks, I might be able to do some loging after all for our trip to townsville over the weekend... okay i am getting a little excited again...
I ate my bowl of Aussie rice for dessert, Main course was imported rice...
Blacky, I have just uploaded the update you sent... and noticed this again..i remeber in the past you asked us to delete the "settings" folder out of the config file...(cant remeber why) I noticed mine keeps appearing even after I have deleted it...
FlashScan will recreate it with the install defaults if it is not there. So you should expect it to re-appear after you delete it.
The only times you would need to delete it are:
1. When a new firmware is released that uses a different format for the settings file (hopefully that won't need to happen again).
2. If you want to reset all the settings to their defaults.
My V2 works in Shane's car with the PLX serial setup ok .as soon as we load 8.1 22/6 the problems starts . the update you sent yesterday is showing problems as well , shane is sending the trace file to you . is there a back door to reload pre 8.1 22/6 untill the problems are worked out
Trace file and logs sent last night Paul, ntae thanks for your efforts last night much appreciated.
Shane
I am seeing this and I am suspecting a sensor timing problem... I will exchange sensors and see... my problem comes on pass thru though...
Post pics/screenshots.
Here it is... its only at WOT...
I guess its a sensor issue because there is more "pressure" at WOT than there is at Part Throttle, so...... sensor is having issues... I will try a different sensor tonight...
