Originally Posted by
WeathermanShawn
First, my "challenge" is meant in the utmost respect, and in the spirit of not only accelerating my own learning curve, but also those other users who obviously struggle with the same aspects of the more intricate concepts involved in the AUTOVE, EFILive tuning concepts.
First off, I don't possess an engineering degree, but as a Meteorologist I do have a fundamental understanding of the properties of thermodynamics, air density, and airflow.
You would be surprised at examples of where the ideal gas law, while accurate in theory, has many pitfalls as it concerns to practical applications. I.E., drive through a significant temperature inversion and watch the dramatic changes in air density, and watch your tune go through some erratic fueling changes.
So, here is my question. I live in a state (Colorado), where elevation, air density, emissions etc, are ultimately going to require me to do the following:
1.) I have done the AutoVe (OLSD). I have also done the AutoVE (OLMAF).
2.) Due to the above mentioned limitations I must adjust to, here are my tuning requirements.
A). I will be running MAF.
B). I will be going back to closed loop utilizing narrow-band O2 readings, trims etc.
Bottom Line: I have spent a good 12 hours searching both LS1tech.com, and EFILive Forums. On LS1tech.com, doing a search of "MAF" brings up 112 pages of numerous opinions, some objective, but a lot highly subjective.
Respectfully, can anyone give as precise of a successful methodology to tune your car for exactly the way that you will be actually running it?
The methodology of AutoVETune, without MAF, and then re-introducing a new calibrated MAF Table back into the VE (SD) calculations, seems to lack a precise mathematical formula to actually substantiate how this blend will actually precisely give you a consistent and accurate AFR.
Proportional MAF BENS, then no proven and precise method to combine VE (SD) and MAF, really makes me question what we are really after.
For myself and apparently for many others, we just want to maintain a target AFR, that still conforms to running a car in closed loop with a MAF, and narrow band output.
Is there any proven method to tune your car to target a AFR under the parameters I mentioned above?
Again, I acknowledge I am a 'one-post' guy. I am missing something, or I am just expessing what others of countless users must also think.
I mean absolutely no disrespect to EFILive, the users of this board. Do I have a point?
So please don't react as this being a negative criticism. Just answer as frankly as possible. Can I command exactly the AFR I want, using Closed loop, O2 feedback., MAF, and SD parameters.
I appreciate the users taking the time to evaluate my perspective, and would appreciate any constructive and educational answers.
Respectfully..
..WeathermanShawn..
