I tried to register.
Made sure that all of the information was correct, the date, everything.
When I click ok, the box goes away but when i restart efi live it is still in demo mode.
What am I doing wrong?
SS, welcome...
Did you enter these items from the blue card:
- the exact serial number,
- the exact issue date,
- the exact key.
For type, set it to "Commercial Scan&Tune".
You have a V2 right...?
Your unit was upgraded before it was shipped. There should have been a white printed sheet with the tune registration. If not, send me an email to ira at fishtuning dot com and I'll email you the code.
Ira
Just a quick FYI. I recently upgraded to 7.54/8.1 BBL and everything went well. However, the tune program kept reverting back to Demo mode even though the correct key was entered. So I deleted all of the key information, saved the change and closed the program. Then I restarted the computer, opened up the program and re-entered the key and it worked. So far so good. I just wanted to pass this along in case someone else ran across the same problem.
