Results 1 to 7 of 7
Thread: TCC lock up
    Aug 2008
    Cool TCC lock up
    I would like to know if it's posible to lock up the tcc in 2 gear now with the new 7.5 ver. or do i have to use a copilot to do so???
    Sep 2006
    Take a look at D5010 and D5065...The TCC will lock up in 2nd gear in T/H, normal mode does so in 3rd...
    2007 CC/SB 4WD, McRat EFI Live, Trans, Trans Cooler and C3 clutch oiling mod by Mike L., SD Sleeves, SoCal Diesel
    2002 CC/DRW 2WD, McRat EFI Live, Trans, Trans Cooler and C3 clutch oiling mod by Mike L., SoCal Diesel
    Aug 2008
    I am sorry did not explaine my self. It does not lock fully or all the time when i am drag racing ,Even with the t/h. i try to adjust it at the lowest mph i can but still won't lock that low when i am drag racing.
    Sep 2006
    Seems to happen when running bigger HP tunes...I've raised shift points to 3600 RPMs and the TCC locks more consistently...Make sure the ECM tune gets adjusted accordingly...
    Nov 2005
    there is a missing table that prevents this when drag racing with big hp. :(
    you can set the converter to lock at 20mph in 2nd gear, but it doesnt listen.
    12.9s @ 108 mph
    many thanks to Ross and Paul
    Jan 2007
    It feels that way with mine but in the logs I have it says it is locked all the way through starting about halfway through second.
    Jan 2007
    I just looked at my log and it looks like it isnt locking untill 3rd. From a stop the duty cycle will jump to 73% for a thenth of a second in second gear then unlock again and not completly lock untill 4th.
    In one run it locks but only locks with about 75% duty cycle then unlocks again in 5th?
    Ive heard rasing shift points to about 3600 helps I have my shift points about 3400rpm.
  1. lOCK pcm
    Last Post: September 14th, 2009, 08:12 AM
  2. tcc lock up to soon
    By kjohns18 in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: June 5th, 2008, 02:32 PM
  3. Need to lock e38
    By CBM in forum E37, E38 & E67 PFI ECM's
    Last Post: December 3rd, 2007, 03:41 AM
  4. Pin lock
    By vortecfcar in forum Duramax LLY
    Last Post: June 4th, 2007, 12:58 AM
