Results 1 to 5 of 5
Thread: Rich...lean...rich...lean......????
    Jan 2007
    Default Rich...lean...rich...lean......????
    Can someone please have a look at this log and tell me if they see anything?
    This just suddenly did this.
    VE was dialled in pretty well prior to this whacky event this evening.
    Have a look at the idling section at the end.
    Didn't feel any different....no stumbles etc.
    Howard
    DUCT TAPE.
    98 K1500 'HOLDEN' Suburban.
    Jan 2007
    A screenshot at idle.
    Howard
    DUCT TAPE.
    You need to log inj pulse width , and the factory O2 sensors for a sanity check.
    Do you have the wideband directly connected to a good 12V source and a good earth ? a cig lighter socket is niether.
    Jan 2007
    Thanks Delco,
    I just ran a log upto op temp and don't see anything causing what I saw yesterday.
    At the start of the log you can see the WBO2 drop out due to me unplugging it to check the connection. Also I see that when disconnected...it shows rich..not lean like I was seeing in the previous log.
    Howard
    DUCT TAPE.
    Jan 2007
    Couldn't seem to replicate the problem.
    Howard
    DUCT TAPE.
  1. running lean when commanding rich
    By Ritch in forum Gen III V8 Specific
    Last Post: June 12th, 2008, 03:37 AM
  2. Please Help Rich then Lean
    By vatman02 in forum Gen III V8 Specific
    Last Post: April 4th, 2008, 12:29 PM
  3. Lean at start up then rich at Idle
    By pwilson22000 in forum Forced Induction and Nitrous Oxide (N20)
    Last Post: August 12th, 2006, 08:19 AM
  4. Lean cruise running rich
    By limited cv8r in forum General (Petrol, Gas, Ethanol)
    Last Post: May 12th, 2006, 01:12 PM
  5. Rich=Lean??
    By DrX in forum General (Petrol, Gas, Ethanol)
    Last Post: April 8th, 2006, 06:27 AM
