Results 1 to 2 of 2
Thread: PLX wideband compatibility question
    Aug 2006
    Default PLX wideband compatibility question
    Is the PLX wideband SM-AFR compatible with EFI live software?
    How about Black box logging to the V1?
    Anything needed to be done to get accurate AFR readings on the V1?
    Jan 2007
    Yes it's compatible....quite a few of us use the PLX WBO2.
    Howard
    DUCT TAPE.
    98 K1500 'HOLDEN' Suburban.
  1. Wideband connection question
    By LS1FREEK in forum FlashScan V2
    Last Post: April 11th, 2010, 11:30 AM
  2. New to efi live / wideband question
    By Toby Van Horn in forum Gen III V8 Specific
    Last Post: November 22nd, 2009, 09:06 AM
  3. Wideband Question
    By tyler84 in forum Gen III V8 Specific
    Last Post: November 11th, 2008, 10:22 AM
  4. Wideband question
    By NewV in forum Gen III V8 Specific
    Last Post: December 10th, 2006, 12:06 AM
  5. Replies: 13
    Last Post: May 17th, 2006, 03:59 AM
