Results 1 to 3 of 3
Thread: L98 Injectors
    Dec 2006
    Default L98 Injectors
    I have been told the STD L98 injectors are 33's.
    Yet looking at the Injector Flow base on a stock 08 tune they appear to be 42's.
    Does anyone have the model number of the injectors?
    The engine is being installed in a earlier model and running from an Ls1 PCM.
    Cheers
    Sean
    Lifetime Member oztracktuning's Avatar
    Nov 2005
    Just use the same numbers in the LS1 tune. Just the staircase region.
    Oztrack
    EFILive Tuning Consultant
    Worldwide Remote Tuning Service
    2006 NSW Super Street Drag Racing Champion
    www.oztrack.com.au
    Dec 2006
    Quote Originally Posted by oztracktuning View Post
    Worked it out Oz.. they are actually 42's.
  1. Low Imp Injectors/Changes
    By tazinhawaii in forum General (Petrol, Gas, Ethanol)
    Last Post: May 31st, 2008, 02:41 PM
  2. 96 lb/hr injectors
    By thosewhohatedmecreatedme in forum General (Petrol, Gas, Ethanol)
    Last Post: September 22nd, 2006, 04:57 AM
  3. Injectors...
    By ZL1Killa in forum General (Petrol, Gas, Ethanol)
    Last Post: August 7th, 2006, 03:11 AM
  4. 96lb/hr injectors can be run like stock injectors with EFILIVE!!
    Last Post: July 24th, 2006, 03:14 PM
  5. Going from 28.8 injectors to SVO 30# injectors
    By 02 pewter Ls1 in forum General (Petrol, Gas, Ethanol)
    Last Post: June 20th, 2005, 01:47 AM
