Hi again
I have another noob question. I am finally getting cracking on with my autoVE. I have been set back by one duff sensor after another. I have intalled the new one and its now doing what it says on the tin....so to speak.
One thing that I need clearing up tho, is the PE modifier based on RPM and the OL commanded table.
How does the PE modifier affect the fuelling and why do you set it at 14.63 during the AutoVE process?
Does this mean that I should see 14.63 on my WB when PE mode is activated or should I see 12.95 as per the autoVE setting in the commanded OL table?
Hope you guys can help novice out here.
BTW, after reading all your posts on idle tuning, I have now waxed the idle. I even got the idle so smooth you cant hear the cam. I was a bit dissapointed so I tweaked around and got it sounding a bit meaner and still keeping a solid idle. This is addictive!!
Thanks for your help!!
