Page 1 of 5 123 ... LastLast
Results 1 to 10 of 41
Thread: URGENT - WARNING for V7.3 USERS - (updated Sep 09 2005)
    Default URGENT - WARNING for V7.3 USERS - (updated Sep 09 2005)
    One of the custom operating systems has fault that will cause a PCM to enter an infinite reset loop. Once the PCM is in that loop it will become unresponsive and can not be reflashed.
    The operating system is 02040003.tun.
    DO NOT FULL-FLASH OPERATING SYSTEM 02040003.tun INTO ANY PCM
    A corrected verison of 02040003.tun is available from this page:
    http://www.efilive.com/downloads/downloads_os.html
    The following calibration tables may be corrupted by EFILive.
    Code:
    D1101 Low Pressure Adjust 1-2 Shift
    D1102 Low Pressure Adjust 2-3 Shift
    D1103 Low Pressure Adjust 3-4 Shift
    D1104 High Pressure Adjust 1-2 Shift
    D1105 High Pressure Adjust 2-3 Shift
    D1106 High Pressure Adjust 3-4 Shift
    D1107 High Pressure Adjust
    These tables define the limits to which the adaptive shift algorithms can adjust the High and Low transmission line pressures.
    EFILive treats the values in these tables incorrectly resulting in incorrect limits being set. The result of having incorrect values in these tables is that adaptive shift learning will be limited to the incorrectly altered values in these tables.
    There is currently no workaround. A new version of EFILive will be released shortly to fix the problem. Once the fix is available, you should check (and update) the values in any of the above tables with known, good, stock calibrations.
    Nov 2003
    I just noticed my values are not right. When are you going to have the fix in Paul?
    Thanks,
    Bill
    2011 Camaro 2SS/RS L99 RJT
    VMax Ported RJT Throttle Body
    Gorilla Wheel Lock System;
    Aug 2004
    Lol, Im 4 days behind on finding all this stuff. I just emailed Paul about the tables this morning.. Looks like he is a couple of days ahead of me..
    It will be available today!
    Nov 2003
    That's fast. It is going to be a patch 001 to 7.3?
    Bill
    Quote Originally Posted by BowlingSS
    Bill
    V7.3 pre-release 004.
    We keep holding off the final delivery of V7.3 in the hopes that at least some 98 support can be included. But that may not happen.
    Nov 2003
    Is the release 004 out yet? I did not see it.
    Bill
    It went out to the beta testers last night.
    I need to fix one or two minor issues that were found, then I'll post it up here in a few hours: http://www.efilive.com/downloads/downloads_730.html
    Oct 2003
    :cry:
    I'd rather be blown, bored... AND stroked!
    Now: 447 CID (Corvette 427) , ATI Procharger D-1SC Supercharger
  1. URGENT PCM Problem
    By ViciousKnid in forum Gen III V8 Specific
    Last Post: August 22nd, 2008, 03:11 AM
  2. IMPORTANT INFORMATION FOR 7.3 USERS (as of Aug 21, 2005)
    By Blacky in forum General (Petrol, Gas, Ethanol)
    Last Post: October 31st, 2005, 06:10 AM
  3. Urgent WARNING for 1998 PCM reflashing
    Last Post: October 24th, 2005, 06:46 PM
  4. URGENT - WARNING for V7.3 USERS
    Last Post: August 25th, 2005, 11:19 AM
  5. Urgent reminder for all WB users.
    By Dirk Diggler in forum General
    Last Post: June 5th, 2005, 10:48 AM
