Then you probably have the same issue as I.
Is 1-2 and 2-3 all 90's?
Yeah the base shift pressure's 1-2 & 2-3 are all normal now, except for the 3-4 base shift pressure which is Maxed out at 90psi across the board......
FLASHSCAN V2 & AUTOCAL
The base shift pressure for 3-4 was fine in 7.5.4 build 66 though.....
