Page 1 of 3 123 LastLast
Results 1 to 10 of 23
Thread: Cat removal
    Nov 2007
    Default Cat removal
    After removing the cat(Yeah Yeah I know) I've considerably lost low end, and maybe 1 - 1.5 mpg where can i compensate in the tune to regain that power and the mpg ?
    Jan 2005
    I can understand, a little, the low end loss, but the decrease in economy is surprising. You might run thru the AutoVE tutorial a bit to see how far off your tune is and adjust accordingly.
    Nov 2007
    Quote Originally Posted by TAQuickness View Post
    Well having a Trailblazer and all, to get the thing to move you need low end...so i guess by pressing a bit harder on it, in the end you spend more gas ? am i wrong in thinking so ?
    The tutorial ? huh ? i can't see that one...is it in the software ?
    thanks
    Oct 2006
    Did you get past the previous problem (reduced power mode , and full flash) ?
    If so how and what was it ?
    2006 Trailblazer
    Jan 2005
    From the Scan or Tune tool help menu click Help -> Tutorials -> AutoVE tutorial. The tutorial is specific to the Gen3 PCM's an may not apply directly to your TB. There are Gen4 specifics floating around the forum somewhere. I'll see if I can find it for you.
    Nov 2007
    Quote Originally Posted by tunedbyGM View Post
    I never had a rep light, i just did'nt want to get one if i removed my tuned pcm and replaced it with a stock one, i am running an efan on the trailblazer, and i know that gm was kind enough to build a pcm that's pretty much useless for any kind of tuning as per what i am seing more and more, nothing comes easy on this one...lol
    for the full flash, the competiton does it, but it also has its flaws
    Nov 2007
    Thanks that would be great...
    I've found the tutorials, but they don't really help me much, i think i might just get a mish mash of both technologies out there, efi live and hp tuners to get what i need done...
    Oct 2006
    Quote Originally Posted by pjaneiro View Post
    I guess I missed the reason for a "Full Flash" , seems only reason for a "Full Flash" is to change the OS , other wise a "Calibration Only" would do the trick !
    Did you contact Jesse Bubb at Wiat4MePerformance , seems he was working on some added .calz for the P10 .
    2006 Trailblazer
    Jan 2005
    Here it is. It's a sticky in the Gen4 section.
    I haven't done much outside the Gen3 PCM's, but I'm thinking you may have the option to utilize the virtual VE table for part of your tuning.
    Nov 2007
    The reason for a full flash is that i am starting to doubt the reliability of efilive when it come to flashing just the cals, i've read a few posts and experienced myself now that some pcms might not take teh flashing on teh first shot, even if it says so, i've had my pcm flashed and i am strating to beleive something failed somewhere, as i still have some options that are not ticked...
    with a full flash at least i could be sure that i do indeed have a working flash or not...works or does not...
  1. 6L80 TM removal?
    By SRT10KLLR in forum 6 speed/8 speed RWD/FWD Transmission Tuning (incl T43, T76, T87)
    Last Post: October 23rd, 2012, 06:50 PM
  2. Idle Air Control Removal
    Last Post: February 20th, 2010, 03:33 PM
  3. Car feels sluggish after MAF removal
    By Alex99 in forum Gen III V8 Specific
    Last Post: August 18th, 2009, 04:36 AM
  4. '06 LBZ speed limiter removal
    By JAY4SPEED in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: November 7th, 2007, 05:37 PM
  5. MAF removal question
    By s10mods in forum Gen III V8 Specific
    Last Post: October 5th, 2007, 02:04 AM
