Do the base spark tables/maps have any effect on timing outside of ide conditions, can they effect your timing at part throttle or WOT?
Is this on an Auto or Manual?
www.efialchemy.com
www.greatamericancarwar.com
My car is an auto, but asking just as a general question.
Refer to B5916 & B5917. Base is generally only used for idle conditions.
Typically, when I tune cars, I set the Base Spark reference in line with the Idle mode and Throttle Cracker settings.
Example:
Base Spark Closed Throttle B5916 - 1.19%
Base Spark Vehicle Speed B5917 - 255 MPH
(this puts you in the base map anytime you're under 1.19% throttle)
Max Speed for Idle B0107 - 4 MPH
Max Throttle for Idle B0108 - 1.19%
(set in line with B5916 & B4312)
Throttle Cracker Activate B4311 - 5 MPH
Throttle Cracker Deactivate B4312 - 4 MPH
This keeps timing simple (you know where to make changes if need be) and it keeps the active idle controls from interfering with the TC settings.
