What scan modes does the LLY ECM support? It seems the default is "Stream-Fast", which limits to 24 channels. Does it support "Dynamic" which it seems would allow up to 36 channels (would be useful IMO)? If it does, how would I set the priority? If I right click a PID, I see the "set Priority to X", but it's greyed out. Most of the "real time" pids you'd want "Priority 1", but PIDs like DSP tune, Battery voltage (If you wanted to log it for some reason), State_XX or IAT are some that I could think to set to a lower priority... Now, if the LLY ECM DOES support "Dynamic", how would one set the V2 to scan in that mode to allow more BBL PIDs?
