Results 1 to 6 of 6
Thread: How to map knock retard?
    Jun 2008
    Default How to map knock retard?
    Hi Everyone,
    I am working on making a knock retard map and have it highlight as I have KR butt I can't get the map to work correctly so far the maps I have made only highlight on the far right column of the map. Notice image below.
    First of I am running in CL and SD when I do AutoVE. So should I have one map for CL and one for SD or one map for both?
    Also I mapping RPM / DYNCYLAIR_DMA is this correct? Or is it RPM / CYLAIR_DMA.
    Thanks Jorge
    GM.DYNCYLAIR_DMA and SAE.RPM.
    Are your scantool and tunetool showing the same units...?
    Jun 2008
    Thanks Joecar,
    I will check that it is exactly that. When I get home toninght.
    Jorge
    Nov 2006
    make sure you select the proper units for the PID.
    metric or imperial.
    Jun 2008
    Thanks,
    My problem was Just that Mr Prick Metric and Imperial
    Ah, the tunetool has nothing to do with it... what was I thinking...
    Glad you got it figured out.
  1. Knock Retard GM.KNKRET vs Retard Due to Knock GM.KR
    By Gelf VXR in forum General (Petrol, Gas, Ethanol)
    Last Post: March 9th, 2008, 04:18 AM
  2. How do I log knock retard?
    By zapp168 in forum General
    Last Post: July 23rd, 2007, 09:32 AM
  3. Knock Retard
    By NAH in forum Forced Induction and Nitrous Oxide (N20)
    Last Post: May 21st, 2007, 11:15 AM
  4. Knock Retard
    By NAH in forum General (Petrol, Gas, Ethanol)
    Last Post: January 29th, 2007, 07:29 AM
  5. knock retard
    By blackblowngto in forum General (Petrol, Gas, Ethanol)
    Last Post: August 5th, 2005, 11:50 AM
