Results 1 to 1 of 1
Thread: Cobalt PIDs that say they don't work really do
    Junior Member yellowC6ohio's Avatar
    Oct 2007
    Default Cobalt PIDs that say they don't work really do
    ok i was logging a cobalt and decided to log some PIDs that say they are not supported just out of curiosity and some of them appear to work.
    has anyone else had any luck with these or can account to their accuracy?
    2 of them that appear accurate are GM.DYNCYLAIR and KR
    this is the data tab while logging, it shows N/A untill the data is saved and reopened then it will show the data.
    this is a map while logging that actually shows the data in real time.
    also i have not been able to find an accurate injector flow rate calc
    and in order to get an accurate commanded AFR use AFR_B
ID:	3729   Click image for larger version.
ID:	3730   Click image for larger version.
  1. scanner buttons work work?
    By pullincrazy88 in forum FlashScan V2
    Last Post: May 16th, 2009, 01:12 PM
  2. 07 Cobalt SS IFR wierdness????
    By Chuck CoW in forum IL6,IL5,IL4 Atlas Engines - P12 PCM
    Last Post: March 1st, 2009, 11:58 AM
  3. 2.2L cobalt 2008
    By duramaxdaddy29 in forum IL4, 97-01 PCM and 02+ P11 PCM
    Last Post: February 21st, 2009, 04:02 AM
  4. BB pids for LMM Allison need work
    By rcr1978 in forum Allison 5 & 6 Speed
    Last Post: February 18th, 2009, 08:56 AM
  5. Support for 06 Cobalt ss/sc 2.0L
    By stkshkr in forum E37, E38 & E67 PFI ECM's
    Last Post: June 12th, 2008, 03:38 PM
