Results 1 to 7 of 7
Thread: new ecm now cant reflash
    Jan 2007
    Default new ecm now cant reflash
    just got truck back from dealer-they replaced ecm-but now do i need another license to flash again?
    its an 08lmm
    08 gmc sierra6.0 4sp-e38/t42 k/n intake
    4x4 ext cab
    Jan 2005
    Unfortunately, yes. Each license is locked to a PCM/TCM. You may want to send an email to support@efilive.com to see if there is anything they can do to help you out.
    Jan 2007
    i was afraid id have to do that
    thanks
    4x4 ext cab
    If you can scan the invoice from the dealer showing they put a new ECM in then we can replace the license for you. Send it to support@efilive.com, it will get to the right people.
    Please mention what happened to the ECM in your Email.
    P.S - Why did they change the ECM?
    Jan 2007
    cool thanks i will get the copy of the invoice
    the ecm was replaced for the engine shutting down
    he kept getting code p0606-
    thanks for the help
    4x4 ext cab
    Jan 2006
    Wow thats cool, Ross would you help me out if I send you my invoice I was one who used the beta update that was wiping the LMM's.
    04 LB7
    2010 LMM
    2015 LML
    Quote Originally Posted by rcr1978 View Post
    My memory must be bad these days, I don't recall killing LMM's.
    Please send me an Email refreshing my memory.
  1. Not able to reflash
    By duramaxdaddy29 in forum Duramax LB7
    Last Post: May 27th, 2008, 10:05 AM
  2. New ECM Reflash
    By Roadrunner in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: March 6th, 2008, 02:22 PM
  3. jca v6 pcm reflash
    By JCA in forum General (Petrol, Gas, Ethanol)
    Last Post: December 7th, 2006, 05:13 PM
  4. Full Reflash
    By Chevy366 in forum Custom Operating Systems
    Last Post: October 24th, 2006, 07:20 AM
