Results 1 to 5 of 5
Thread: Filter Sets
    Nov 2006
    Default Filter Sets
    how exactly are the filter sets applied?
    if there are 2 PIDs on filter set #1 are they linked together? (with and)
    or must you separate them?
    one PID on filter set #1 and, the other on filter set #2 (for or)
    example:
    SAE.TP - varies by 5.00% and
    SAE.RPM - less than 400 RPM
    or is it
    SAE.TP - varies by 5.00% or
    if 2 or more PIDs are on the same tab.
    in the filter properties of the scan.exe
    you chose how/if they are to be linked. (and/or)
    i always thought that the each PID is excluded on it`s own.
    but now that i think of it,
    how would you combine 2 or more PIDs
    to exclude at the same time?
    how i understood the manual is that it filters each on it`s own and,
    there is`nt a clear way to combine 2 or more.
    i assumed there are 2 filter sets for a combined 8 PIDs,
    but it makes sense that there are 2 separate sets as to
    combine (on the same filter set) or separate them .
    am i making sense?
    Jan 2007
    I think it's AND.
    I know on a cold morning when ECT's are below the 70oC I have set in the filter (exclude ECT's below 70oC) it won't update.
    I also have TP set at 'exclude below 1%'.
    Whilst idling....
    If I 'untick' the ECT filter....it still won't update until I 'untick' the TPS filter.
    Howard
    DUCT TAPE.
    98 K1500 'HOLDEN' Suburban.
    Jan 2005
    RTACS is "and"
    Nov 2006
    Quote Originally Posted by hquick View Post
    I think it's AND.
    Whilst idling....
    so when the car reaches over 70C it will update?
    TP% alone would keep it from making changes at idle regardless of ECT.
    Quote Originally Posted by TAQuickness View Post
    RTACS is "and"
    if 2 or more PIDs are on separate filter sets, does that put or between them?
    Jan 2007
    It'll only update at 70oC if TPS is also above 1%.
    I think it's still 'and' regardless of the filter set.
    I guess Paul or Ross could answer this best.
    Howard
    DUCT TAPE.
  1. Fuel Filter
    By Shaftner87 in forum Duramax LLY
    Last Post: May 9th, 2010, 02:01 AM
  2. AutoVE filter
    By Gelf VXR in forum General (Petrol, Gas, Ethanol)
    Last Post: October 5th, 2009, 04:00 AM
  3. Particle Filter
    By nqcv8 in forum General (Diesel)
    Last Post: April 11th, 2008, 01:18 PM
  4. wideband filter?
    By pwilson22000 in forum General
    Last Post: July 13th, 2006, 05:10 AM
  5. Filter Question??
    By BowlingSS in forum General (Petrol, Gas, Ethanol)
    Last Post: July 27th, 2005, 10:13 AM
