Results 1 to 2 of 2
Thread: EFILive 7/.5/8.1 question... where to ask?
    Aug 2007
    Thumbs down SOLVED. EFILive 7.5/8.1 install question...
    UPDATE: Now, I cant install the latest 8.1. It says that is must install the previous version of 8.1 (which there is none) and then it errors with Error Code 2718. I have wiped every trace of EFILive and InstallAware from the PC and the 8.1 install still thinks there is a previous version of 8.1.
    Where else does the install routine place files or settings?
    I searched and found nothing. :(
    ORIGINAL POST: I dont know if I should ask this here or where... but I have noticed several times on my PC with the latest BBL release... I will go to start the 8.1 Auto Update Config wizard.. and I get an error that EFILive8.1.xxx.exe cannot be found. Then I look in my 8.1 folder and there are duplicates of all of the folders. The second copies of the folder have a "(2)" at the end of the name?
    Is this supposed to happen? I have uninstalled and reinstalled several times, cleaned the registry and get the same thing. It only happens after a few days... maybe the auto update runs and messes things up? I have never seen this before.
    The next time it happens, I will post a screenshot.
    2002 WS6, All-Lunati 383 Strok'r @11:1, Cartek Heads, Keith/Ross Racing Custom Cam, Victor Jr., 492whp 457wtq,
    Cartek Clutch, 9" Moser w/4.11's, 35 spline Detroit Locker, QA1's, NX, BMR, Tuned w/ EFILive V2 Black Box Logging
    Check Out My Latest Tune File: HERE
    Aug 2007
    Talking
    SOLVED IT.
    Turns out, the EFILive auto update I had set to auto-download and auto-install. The Installation was frozen or hung. I suspect this was due to McAfee's System Guard (a feature in their AV Suite) but I could not tell for sure. I combed the registry and filesystem and found no traces of an 8.1x install. I had to use the following tool from Microsoft to fix the hung/corrupted install.
    The Microsoft Windows Installer CleanUp Utility
    http://support.microsoft.com/default...b;en-us;290301
    I ran it, it unstuck the hung install, then I got a list of installed or partially installed apps. At the top was the v8.1.xxx install. I selected it and clicked remove. WHam. Now I can install v8.1 and v7.5x with no errors or problems.
  1. Replies: 14
    Last Post: May 29th, 2009, 05:16 AM
  2. 12200411 retrofit, have efilive "VIN" question
    By rb1 in forum Gen III V8 Specific
    Last Post: June 2nd, 2007, 07:39 AM
  3. question for efilive
    By dmax in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: May 3rd, 2007, 01:56 AM
  4. EfiLive file format question...............
    By FreddyG in forum Gen III V8 Specific
    Last Post: January 4th, 2007, 11:29 AM
  5. EFILive vs Handheld question
    By NewV in forum General (Petrol, Gas, Ethanol)
    Last Post: December 12th, 2006, 02:05 AM
